移植后出现乱码
1851|2
xsgy123|  楼主 | 2012-1-5 21:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
昨天终于将uboot移植到mini2440上了,开机重启后串口输出了很正常的菜单
[1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash
[2] Download Eboot to Nand Flash
[3] Download Linux Kernel to Nand Flash
[5] Download CRAMFS image to Nand Flash
[6] Download YAFFS image to Nand Flash
[7] Download Program (uCOS-II or TQ2440_Test) to SDRAM and Run it
[8] Boot the system
[9] Format the Nand Flash
[0] Set the boot parameters
[a] Download User Program (eg: uCOS-II or TQ2440_Test)
Download ** Picture (.bin) to Nand Flash
[l] Set LCD Parameters
[o] Download u-boot to Nor Flash
[r] Reboot u-boot
[t] Test Linux Image (zImage)
[q] quit from menu
但是,输入出现了乱码问题,很奇怪的是,输入数字和标点符号都没有问题,输入字母就有一大半出现乱码,是在是搞不清楚什么原因?
txcy| | 2012-1-5 22:15 | 只看该作者
时钟设置有问题
秋天落叶| | 2012-1-5 22:28 | 只看该作者
楼主检查一下时钟设置
