串口数据的解析。 - /*****************************************************
- *函数名称:void UartRecvAnalysisDeal(void)
- *函数功能:解析串口接收数据处理
- *入口参数:void
- *出口参数:void
- void UartRecvAnalysisDeal(void)
- UartRecv();
- if(RecvFlag==1) //判断是否接收完
- RecvFlag = 0;
- Uart_Send_String(RecvBuf);
- if(RecvBuf[0] == '#') //判断启示标志位
- //1.LED
- if((RecvBuf[1]=='L')&&(RecvBuf[2]=='E')&&(RecvBuf[3]=='D'))
- if (RecvBuf[4] == '0')
- LED_OFF;
- Uart_Send_String("#LED0\r\n");
- if (RecvBuf[4] == '1')
- LED_ON;
- Uart_Send_String("#LED1\r\n");
- //2.BEP
- else if((RecvBuf[1]=='B')&&(RecvBuf[2]=='E')&&(RecvBuf[3]=='P'))
- BEP_OFF;
- Uart_Send_String("#BEP0\r\n");
- BEP_ON;
- Uart_Send_String("#BEP1\r\n");
- //3.SMG
- else if((RecvBuf[1]=='S')&&(RecvBuf[2]=='M')&&(RecvBuf[3]=='G'))
- num1 = RecvBuf[4] - 0x30;
- num2 = RecvBuf[5] - 0x30;
- num3 = RecvBuf[6] - 0x30;
- num4 = RecvBuf[7] - 0x30;
- //5.EEPROM Write
- else if((RecvBuf[1]=='E')&&(RecvBuf[2]=='E')&&(RecvBuf[3]=='P')&&(RecvBuf[4]=='W'))
- startaddr = (RecvBuf[5]-0x30)*100 +(RecvBuf[6]-0x30)*10 + (RecvBuf[7]-0x30);
- len = (RecvBuf[8]-0x30)*100 + (RecvBuf[9]-0x30)*10 + (RecvBuf[10]-0x30);
- dater = (RecvBuf[11]-0x30)*100 + (RecvBuf[12]-0x30)*10 + (RecvBuf[13]-0x30);
- for(i=startaddr;i<len;i++)
- EEPROM_WriteOneByte(i,dater);
- USCI0_TWI_Delay(2500);
- // Uart_Send_String("写入完成\r\n");
- //6.EEPROM Read
- else if((RecvBuf[1]=='E')&&(RecvBuf[2]=='E')&&(RecvBuf[3]=='P')&&(RecvBuf[4]=='R'))
- temp = EEPROM_ReadOneByte(i);
- Uart_Send_Byte('!');
- Uart_Send_Byte(temp/100+0x30);
- Uart_Send_Byte(temp%100/10+0x30);
- Uart_Send_Byte(temp%10+0x30);
- Uart_Send_Byte('\r');
- Uart_Send_Byte('\n');
