[STM32F0] 无法进入接收中断
687|8
 楼主| morrisk 发表于 2020-8-15 19:44 | 显示全部楼层 |阅读模式
STM32F091芯片USART3~USART8无法进入接收中断
zhuhuis 发表于 2020-8-15 19:49 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| morrisk 发表于 2020-8-15 19:55 | 显示全部楼层
static void RCC_Configuration(void)
  /* Enable GPIO clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB|RCC_AHBPeriph_GPIOC|RCC_AHBPeriph_GPIOD|RCC_AHBPeriph_GPIOF, ENABLE);
  /* Enable 8xUSARTs Clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2|RCC_APB1Periph_USART3|RCC_APB1Periph_USART4|RCC_APB1Periph_USART5, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART6|RCC_APB2Periph_USART7|RCC_APB2Periph_USART8|RCC_APB2Periph_USART1, ENABLE);
static void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* USART1 IRQ Channel configuration */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0x01;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* USART2 IRQ Channel configuration */
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  /* USART3_8 IRQ Channel configuration */
  NVIC_InitStructure.NVIC_IRQChannel = USART3_8_IRQn;
/* USART3 Pins configuration  ***********************************************/
  /* Connect pin to Periph */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_4);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_4);
  /* Configure pins as AF pushpull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
USART_InitStructure.USART_BaudRate = 9600;
          USART_InitStructure.USART_WordLength = USART_WordLength_8b;
          USART_InitStructure.USART_StopBits = USART_StopBits_1;
          USART_InitStructure.USART_Parity = USART_Parity_No;
          USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
          USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART3, &USART_InitStructure);
              /* Enable 8xUSARTs Receive interrupts */
              USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
              /* Enable the 8xUSARTs */
              USART_Cmd(USART3, ENABLE);
void USART3_8_IRQHandler(void)
if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
          dumm = USART_ReceiveData(USART3);
         // if(Usart_RxSetp(UsartIndex,dumm) == 0)return;
          Usart_RxSetp(UsartIndex,dumm);
请帮忙看看USART3无法进入接收中断,能正常发送。当有数据时即进入死循环函数:
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
juventus9554 发表于 2020-8-15 20:03 | 显示全部楼层
没用过这个,能用图形化配置吗
 楼主| morrisk 发表于 2020-8-15 20:07 | 显示全部楼层
USART1和USART2能正常接收,USART3~USART8都不行,收到数据就进入死循环。
houcs 发表于 2020-8-15 20:11 | 显示全部楼层
打断点 看看死在哪个语句上了呀
pangb 发表于 2020-8-15 20:14 | 显示全部楼层
中断函数里边卡死的?
 楼主| morrisk 发表于 2020-8-15 20:22 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
稳稳の幸福 发表于 2020-8-15 21:43 | 显示全部楼层
解决了吗,啥情况导致的?
