最近公司上新项目,新平台很忙 都没写 真是惭愧!现在赶紧补上。
1.8寸TFT 是ST7735的驱动芯片,是SPI方式驱动,数据口只有五个。
赶紧上代码吧!
补几张照片 ,哈哈!
主文件-
- #include <stdio.h>
- #include "NUC1xx.h"
- #include "DrvUART.h"
- #include "DrvSYS.h"
- #include "DrvSPI.h"
- #include "DrvPDMA.h"
- #include "SPI_FLASH_PDMA.h"
- #include "ST7735R_SPI.H"
- #include "Driver\DrvGPIO.h"
- #define RW_LEN 80
- #define DelayCnt 500
- extern void Test_picture(uint8_t *map);
- extern unsigned char gImage_hotpower[];
- extern unsigned char gImage_hotpage[];
- uint8_t SPI_PDMA_RXBuf[RW_LEN];
- uint8_t SPI_PDMA_TXBuf[RW_LEN];
- void RCC_Config(void);
- void UART_Config(void);
- int main()
- RCC_Config();
- UART_Config();
- SPI_Init();
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| NUC120助学板之SPI ---TFT_ST7735 |\n");
- printf("***NUC120***配置主频为: %2d MHz.\n",DrvSYS_GetHCLKFreq()/1000000);
- printf("---SPI0主机模式,频率为: %2d MHz.\n", DrvSPI_GetClock1Freq(eDRVSPI_PORT0)/1000000);
- //设置PA5为输出,PA5为RESET
- DrvGPIO_Open(E_GPB,10, E_IO_OUTPUT);
- GPIOB->DOUT &= ~(1 << 10);
- TFT_INIT();
- while(1)
- RamAdressSet();
- TFT_Single_Colour(0xf800); //红
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0x07e0); //绿
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0x001f); //蓝
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0xf81f); //黄
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0xffe0); //青
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0x07ff); //紫
- delay(DelayCnt);
- RamAdressSet();
- TFT_Single_Colour(0xffff); //白
- delay(DelayCnt);
- Test_picture(gImage_hotpower) ; //大叔
- delay(DelayCnt*5);
- Test_picture(gImage_hotpage) ; //大叔小孩
- UNLOCKREG();
- SYSCLK->WRCON.XTL12M_EN = 1;
- // Waiting for 12M Xtal stalble
- DrvSYS_Delay(5000);
- //HCLK 为外部12M 通过PLL倍频到 50MHz.
- DrvSYS_Open(50000000);
- LOCKREG();
- void UART_Config()
- STR_UART_T sParam;
- // Set UART I/O
- DrvGPIO_InitFunction(E_FUNC_UART0);
- //Select UART Clock Source From 12MHz
- DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC, 0);
- // UART Setting
- sParam.u32BaudRate = 9600;
- sParam.u8cDataBits = DRVUART_DATABITS_8;
- sParam.u8cStopBits = DRVUART_STOPBITS_1;
- sParam.u8cParity = DRVUART_PARITY_NONE;
- sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
- // Set UART Configuration
- DrvUART_Open(UART_PORT0, &sParam);
SPI驱动TFT- void LCD_Write_CMD(uint8_t CMDTmp)
- uint32_t au32SourceData;
- //configure transaction length as 8 bits
- DrvSPI_SetBitLength(eDRVSPI_PORT0, 8);
- //CS =0
- RS_LOW;
- au32SourceData = CMDTmp;
- DrvSPI_SingleWrite(eDRVSPI_PORT0, &au32SourceData);
- // wait
- while (DrvSPI_IsBusy(eDRVSPI_PORT0)) {}
- void LCD_Write_DATA8B(uint8_t DataTmp)
- // configure transaction length as 8 bits
- //CS =1
- RS_HIGH;
- au32SourceData = DataTmp;
- // wait
- void LCD_Write_DATA16B(uint16_t LCD_Data)
- DrvSPI_SetBitLength(eDRVSPI_PORT0, 16);
- //CS =1
- RS_HIGH;
- au32SourceData = LCD_Data;
- //while(!DrvSPI_SingleWrite(eDRVSPI_PORT1, &au32SourceData)){}
- // wait
- void TFT_RESET(void)
- RESET_LOW;
- delay(100);
- RESET_HIGH;
- delay(100);
- void TFT_INIT(void)
- RESET_LOW;
- delay(10);
- RESET_HIGH;
- delay(10);
- //-------------------Software Reset-------------------------------//
- LCD_Write_CMD(0x11);//Sleep out
- delay(5);
- //ST7735R Frame Rate
- LCD_Write_CMD(0xB1);
- LCD_Write_DATA8B(0x01);
- LCD_Write_DATA8B(0x2C);
- LCD_Write_DATA8B(0x2D);
- LCD_Write_CMD(0xB2);
- LCD_Write_CMD(0xB3);
- //------------------------------------End ST7735R Frame Rate-----------------------------------------//
- LCD_Write_CMD(0xB4);//Column inversion
- LCD_Write_DATA8B(0x07);
- //------------------------------------ST7735R Power Sequence-----------------------------------------//
- LCD_Write_CMD(0xC0);
- LCD_Write_DATA8B(0xA2);
- LCD_Write_DATA8B(0x02);
- LCD_Write_DATA8B(0x84);
- LCD_Write_CMD(0xC1);
- LCD_Write_DATA8B(0xC5);
- LCD_Write_CMD(0xC2);
- LCD_Write_DATA8B(0x0A);
- LCD_Write_DATA8B(0x00);
- LCD_Write_CMD(0xC3);
- LCD_Write_DATA8B(0x8A);
- LCD_Write_DATA8B(0x2A);
- LCD_Write_CMD(0xC4);
- LCD_Write_DATA8B(0xEE);
- //---------------------------------End ST7735R Power Sequence-------------------------------------//
- LCD_Write_CMD(0xC5);//VCOM
- LCD_Write_DATA8B(0x0E);
- LCD_Write_CMD(0x36);//MX, MY, RGB mode
- LCD_Write_DATA8B(0xC8);//C8 //自上而下,自左向右,BGR扫描显示。
- //------------------------------------ST7735R Gamma Sequence-----------------------------------------//
- LCD_Write_CMD(0xe0);
- LCD_Write_DATA8B(0x1c);
- LCD_Write_DATA8B(0x12);
- LCD_Write_DATA8B(0x37);
- LCD_Write_DATA8B(0x32);
- LCD_Write_DATA8B(0x29);
- LCD_Write_DATA8B(0x2d);
- LCD_Write_DATA8B(0x25);
- LCD_Write_DATA8B(0x2b);
- LCD_Write_DATA8B(0x39);
- LCD_Write_DATA8B(0x03);
- LCD_Write_DATA8B(0x10);
- LCD_Write_CMD(0xe1);
- LCD_Write_DATA8B(0x1d);
- LCD_Write_DATA8B(0x06);
- LCD_Write_DATA8B(0x2e);
- LCD_Write_DATA8B(0x2c);
- LCD_Write_DATA8B(0x3f);
- LCD_Write_CMD(0x2A); //Column Address Set
- LCD_Write_DATA8B(0x7F);
- LCD_Write_CMD(0x2B); //Row Address Set
- LCD_Write_DATA8B(0x00); //01
- LCD_Write_DATA8B(0x9F); //A0
- //------------------------------------End ST7735R Gamma Sequence-----------------------------------------//
- //设置显示色彩 12位(4k,03h),16位(65k,05h),18位(262k,06h)。
- LCD_Write_CMD(0x3A);
- LCD_Write_DATA8B(0x05); //262k mode
- LCD_Write_CMD(0x29);//Display on
- delay(10);
- void RamAdressSet(void)
- LCD_Write_DATA8B(0x81);
- LCD_Write_DATA8B(0xA0);
- LCD_Write_CMD(0x2C);//Write DATA TO RAM
- void LCD_DataWrite(uint8_t LCD_DataH,uint8_t LCD_DataL)
- LCD_Write_DATA8B(LCD_DataH);
- LCD_Write_DATA8B(LCD_DataL);
- void TFT_Single_Colour(uint16_t SCDATA)
- uint8_t i,j;
- for (i=0;i<128;i++)
- for (j=0;j<160;j++)
- LCD_Write_DATA16B(SCDATA);
- void Test_picture(uint8_t *map)
- int j;
- RamAdressSet();
- for(j=0;j<(128*160);j++)
- LCD_DataWrite(map[2*j+1],map[2*j]);
