STM32F103在进入ADC_Cmd里死机问题请教
4800|4
 楼主| Progrime 发表于 2012-1-8 22:25 | 显示全部楼层 |阅读模式
大家好:
  我在调试32的ADC时,进入ADC_Cmd就死机,JTAG断线,找不到CPU,重启板子电源也不行,必须要用ISP模式启动,JTAG才找得到CPU,探险FLASH后,再从正常模式下启动才能找得到CPU。软件是V2.0.3版本,请教,谢谢,
72Mhz系统频率,PA口和ADC1的时钟以开。
RCC_HCLKConfig   (RCC_SYSCLK_Div1);   /* HCLK   = SYSCLK  */
  RCC_PCLK2Config  (RCC_HCLK_Div1);     /* PCLK2  = HCLK    */
  RCC_PCLK1Config  (RCC_HCLK_Div2);     /* PCLK1  = HCLK/2  */
  RCC_ADCCLKConfig (RCC_PCLK2_Div6);    /* ADCCLK = PCLK2/6 */
  /* PLLCLK = 8MHz * 9 = 72 MHz */
  RCC_PLLConfig (RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//9
  RCC_PLLCmd (ENABLE);                  /* Enable PLL */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF |
           RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOG | RCC_APB2Periph_AFIO  |
    RCC_APB2Periph_ADC1  | RCC_APB2Periph_ADC2 | RCC_APB2Periph_SPI1,ENABLE);  //RCC_APB2Periph_GPIO_CS|
         /* Enable PWR and BKP clock */
ADC初使化程序如下:
void AdcApp_Init(void)
  ADC_InitTypeDef ADC_InitStructure;
  GPIO_Init(ADC_PORT, (GPIO_InitTypeDef*)(&AdcPort));
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;//DISABLE; //
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //DISABLE
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//ADC_ExternalTrigConv_Ext_IT11
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_DeInit(ADC1);
  ADC_Init(ADC1, &ADC_InitStructure);
  ADC_ITConfig(ADC1,ADC_IT_EOC|ADC_IT_AWD|ADC_IT_JEOC,DISABLE);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_1,1,ADC_SampleTime_55Cycles5); // ADC_SampleTime_28Cycles5
  ADC_Cmd(ADC1, ENABLE);
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
香水城 发表于 2012-1-9 12:03 | 显示全部楼层
ADC_Cmd是什么?
雨辰073 发表于 2012-1-9 16:47 | 显示全部楼层
能把你的ADC使用的管脚GPIO的配置那一部分给出来看看不?有可能是JTAG的管脚被占用
雨辰073 发表于 2012-1-9 16:48 | 显示全部楼层
就是这一部分的具体配置拿出来看看(GPIO_Init(ADC_PORT, (GPIO_InitTypeDef*)(&AdcPort)); )
 楼主| Progrime 发表于 2012-1-10 13:33 | 显示全部楼层
谢谢大师虾们,搞定了,原来是VDDA电源太低了,低于2.4V了,
