[MCU] 怎么生成一个复杂的pwm波?
1242|37
 楼主| pangb 发表于 2020-8-27 20:09 | 显示全部楼层 |阅读模式
它的高低电平情况是:
1111000 1111000 1111000 1111000 1111000 1111000 1111000 0001111 0001111 0001111 0001111 0001111 0001111 0001111
wangpe 发表于 2020-8-27 20:14 | 显示全部楼层
加个变频的代码
huwr 发表于 2020-8-27 20:18 | 显示全部楼层
ePWM模块,看你需要哪种调制方式,都能输出啊
chenho 发表于 2020-8-27 20:24 | 显示全部楼层
变换这么多次  也能用pwm模块吗
chuxh 发表于 2020-8-27 20:27 | 显示全部楼层
不是只有zro prd cmpa  cmpb可以用来动作吗?
renyaq 发表于 2020-8-27 20:31 | 显示全部楼层
是在pwm模块定时中断里面加吗?
liuzaiy 发表于 2020-8-27 20:35 | 显示全部楼层
interrupt void epwm3_timer_isr(void)
        EPwm3TimerIntCount++;
    switch(EPwm3Regs.CMPA.half.CMPA)
        case 1435:
                     EPwm3Regs.CMPA.half.CMPA=3348;
        break;
        case 3348:
                EPwm3Regs.CMPA.half.CMPA=4783;
        break;
        case 4783:
                EPwm3Regs.CMPA.half.CMPA=6696;
        break;
        case 6696:
                EPwm3Regs.CMPA.half.CMPA=8131;
        break;
        case 8131:
                EPwm3Regs.CMPA.half.CMPA=10044;
        break;
        case 10044:
                    EPwm3Regs.CMPA.half.CMPA=11479;
        break;
        case 11479:
                EPwm3Regs.CMPA.half.CMPA=13392;
        break;
        case 13392:
                    EPwm3Regs.CMPA.half.CMPA=14827;
        break;
        case 14827:
                EPwm3Regs.CMPA.half.CMPA=16740;
        break;
        case 16740:
                EPwm3Regs.CMPA.half.CMPA=18175;
        break;
        case 18175:
                EPwm3Regs.CMPA.half.CMPA=20088;
        break;
        case 20088:
                EPwm3Regs.CMPA.half.CMPA=21522;
        break;
        case 21522:
                    EPwm3Regs.CMPA.half.CMPA=25349;
        break;
        case 25349:
                EPwm3Regs.CMPA.half.CMPA=26783;
        break;
        case 26783:
                    EPwm3Regs.CMPA.half.CMPA=28697;
        break;
        case 28697:
                EPwm3Regs.CMPA.half.CMPA=30131;
        break;
        case 30131:
                EPwm3Regs.CMPA.half.CMPA=32045;
        break;
        case 32045:
                EPwm3Regs.CMPA.half.CMPA=33479;
        break;
        case 33479:
                EPwm3Regs.CMPA.half.CMPA=35392;
        break;
        case 35392:
                    EPwm3Regs.CMPA.half.CMPA=36827;
        break;
        case 36827:
                EPwm3Regs.CMPA.half.CMPA=38740;
        break;
        case 38740:
                EPwm3Regs.CMPA.half.CMPA=40175;
        break;
        case 40175:
                EPwm3Regs.CMPA.half.CMPA=42088;
        break;
        case 42088:
                EPwm3Regs.CMPA.half.CMPA=43523;
        break;
    case 43523:
            EPwm3Regs.CMPA.half.CMPA=45436;
        break;
        case 45436:
                EPwm3Regs.CMPA.half.CMPA=1435;
        break;
            default:
            break;
    EPwm3Regs.ETCLR.bit.INT = 1;
    PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
 楼主| pangb 发表于 2020-8-27 20:50 | 显示全部楼层
EPwm3Regs.AQCTLA.bit.ZRO=AQ_SET;
    EPwm3Regs.AQCTLA.bit.CAU=AQ_TOGGLE;
    EPwm3Regs.ETSEL.bit.INTSEL = ET_CTRU_CMPA;
    EPwm3Regs.ETSEL.bit.INTEN = PWM3_INT_ENABLE;
    EPwm3Regs.ETPS.bit.INTPRD = ET_1ST;
这是我pwmsetup里的  是增计数模式
lium 发表于 2020-8-27 20:53 | 显示全部楼层
给一个合适的比较表吧
梵蒂冈是神uy 发表于 2020-8-29 22:24 | 显示全部楼层
         case 1435:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:25 | 显示全部楼层
        case 3348:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:26 | 显示全部楼层
        case 4783:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:27 | 显示全部楼层
case 6696:
         break;
case 8131:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:28 | 显示全部楼层
case 10044:
         break;
case 11479:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:30 | 显示全部楼层
case 13392:
         break;
case 14827:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:31 | 显示全部楼层
case 16740:
         break;
梵蒂冈是神uy 发表于 2020-8-29 22:32 | 显示全部楼层
case 18175:
         break;
