Program start from RAM
259|0
 楼主| スモモ 发表于 2018-9-9 07:42 | 显示全部楼层 |阅读模式
I tried simple code using Keil MDK5 for STM32F769 CPU. I\'ve used Keil simulator and noticed that vector table is settled at 0 (ITCM RAM) with BOOT_ADDRx =0, directing CPU to start from 0. The question is how vector table was filled in RAM. If JTAG did it, what will happen when I don\'t have JTAG, ie in production ? If some code from flash did it, how CPU started from flash at the first place, if at least stack addr should be at 0 ?
