BCC vs BNE
107|0
スモモ|  楼主 | 2018-9-9 09:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, ST, ck, se, RS
To detect negative numbers why do programming use BCC (check carry bit ) instead of BNE ( check N bit , which is obviously more straightforward ) ?
