How to do from Secure(EL3)
217|0
 楼主| kaloulin 发表于 2018-9-9 10:28 | 显示全部楼层 |阅读模式
Hi all i trying do transition from EL3 to EL2 exception ,but after ERET of EL3 mode it change the mode to EL2 , but as soon as when it will execute first instruction of EL2 , then It goes to Exception ...
This is happen for every secure to non secure transition in Armv8-A .
Please Guide if you know why this happen?
Thank you in advance.
