What purpose does BURST feature in AHB serve?
389|0
 楼主| 河童 发表于 2018-9-9 11:50 | 显示全部楼层 |阅读模式
I am not able to see any visible improvements due to the BURST transfers. The same BURST transfer could be done through multiple SINGLE transfers, in the same number of cycles. Then what is te advantage of having BURST transfers?
