QT5.9写的文件传输小程序源码
264|0
 楼主| 冷冻链 发表于 2018-9-11 13:56 | 显示全部楼层 |阅读模式
include "recive.h"
#include "ui_recive.h"
recive::recive(QWidget *parent) :
    QMainWindow(parent),
    ui(new Ui::recive)
    ui->setupUi(this);
recive::~recive()
    delete ui;
void recive::on_pushButton_clicked()
    socket = new QTcpSocket;
    QString ip = ui->lineEdit->text();
    quint16  port = ui->lineEdit_2->text().toUShort();
    socket->connectToHost( QHostAddress(ip),port);
    connect(socket,SIGNAL(connected()),this,SLOT(is_connected()));
    connect(socket,SIGNAL(readyRead()),this,SLOT(recv_Read()));
    recive_size = 0;
void recive::is_connected()
     ui->textEdit->append("和服务器连接成功,请选择要保存的文件夹路径.......");
void recive::recv_Read()
//开始接收头解析
        QByteArray head;
        QString str_size;
        head = socket->readAll();
        filename = QString(head).section("##",0,0);
        size =  QString(head).section("##",1,1).toULongLong();
        ui->textEdit->append("文件名:"+filename+"    "+"文件大小:"+str_size.setNum(size)+"kb");
        socket->write("66");
        //=======打开文件=========
         file.setFileName(filePath+"/"+filename);
        if( false== file.open(QFile::WriteOnly))
               ui->textEdit->append("文件打开有误....");
        else
               ui->textEdit->append("文件打开写成功....");
        disconnect(socket,SIGNAL(readyRead()),this,SLOT(recv_Read()));
        connect(socket,SIGNAL(readyRead()),this,SLOT(recv_Read1()));
       my_timer = new QTimer;
       connect(my_timer,SIGNAL(timeout()),this,SLOT(timer_hand()));
       my_timer->start(1000);
void recive::timer_hand()
    quint32 speed_size;
    static quint64 last_size = 0,count = 0;
     speed_size = recive_size-last_size;
     if(speed_size == 0)
        count++;
     if(count>5) {  this->~recive();  }
     last_size =recive_size;
    QString str;
    QString str1;
      str1.setNum(speed_size);
    if(recive_size<1024)
         str.setNum(recive_size);
        ui->lineEdit_3->setText("接受数据:"+str+"Kb"+"网速:"+str1+"KB");
        return ;
    if(recive_size/1024>0 && (recive_size/1024)<1024 )
         str.setNum(recive_size/1024);
        ui->lineEdit_3->setText("接受数据:"+str+"Mb"+"网速:"+str1+"KB");
        return ;
    if((recive_size/1024)/1024 >0  )
             str.setNum(recive_size/1024/1024);
             ui->lineEdit_3->setText("接受数据:"+str+"Gb"+"网速:"+str1+"KB");
void recive::recv_Read1() //正式接受文本内容
    QString str;
    QByteArray text = socket->readAll();
    file.write(text);
    recive_size++;
void recive::on_pushButton_2_clicked()
     filePath = QFileDialog::getExistingDirectory(this, "choose src Directory","/");
    if(filePath.isEmpty() == false )
        ui->textEdit->append("文件路径:"+filePath);
        socket->write("55");
    else
        ui->textEdit->append("文件选择路径有误....");
#include "send.h"
#include "ui_send.h"
send::send(QWidget *parent)
    : QMainWindow(parent)
    , ui(new Ui::send)
    ui->setupUi(this);
    ui->pushButton_2->setEnabled(false);
    ui->pushButton_3->setEnabled(false);
send::~send()
    delete ui;
void send::on_pushButton_clicked()
    server = new QTcpServer;
    QString ip = ui->lineEdit_2->text();
    quint16 port = ui->lineEdit->text().toUShort();
    if(true == server->listen(QHostAddress(ip),port))
        ui->textEdit->append("此id监听成功....");
    else
          ui->textEdit->append("此id监听失败....");
    connect(server,SIGNAL(newConnection()),this,SLOT(handconnect()));
void send::handconnect() //一个新的连接
{   static bool sever_falg = 0;
    if(sever_falg == 0) //阻止其他客户端连接
        sever_falg = 1;
         ui->pushButton->setEnabled(false);
         ui->pushButton_2->setEnabled(true);
         ui->pushButton_3->setEnabled(true);
         socket = new QTcpSocket;  //这个socket 为 读写通信socket
         socket = server->nextPendingConnection();
         QString ip_str1 = socket->peerAddress().toString();
         QString  ip_str2 = ip_str1.section(':',3);
         ui->textEdit->append ("接受端IP:"+ip_str1 );
        // connect(socket,SIGNAL(readyRead()),this,SLOT(send_read()));
    else
        sever_falg = 1;
        return ;
void send::send_read()
      QByteArray  ackbuff;
      ackbuff = socket->read(2);
      if(ackbuff.toShort() == 66 )   ui->textEdit->append("文件头发送成功....");
      my_timer->start(1);
     ui->textEdit->append("开始发送文本内容........");
      // emit write_flag();
void send::send_text()  //空函数
void send::timer_hand() //===发送文本内容
   static quint32 count = 0;
    qint64 len = 0;
    char buf[1024*5];
    len = file.read(buf,sizeof(buf));
    socket->write(buf,len);
    if(len <= 0)
        ui->textEdit->append("文件发送成功........");
        if(my_timer->isActive() == true )
            my_timer->stop();
            this->~send();
        return ;
    count++;
void send::on_pushButton_3_clicked()  //发送文件
     QByteArray  ackbuff;
     if(ackbuff.toShort() == 55 )
         ui->textEdit->append("连接成功....");
         ui->textEdit->append("开始发送文件头....");
         QString head = QString("%1##%2").arg(filename).arg(size/1024);
         socket->write(head.toUtf8());
        // connect(this,SIGNAL(write_flag()),this,SLOT(send_text()));  //连接信号和曹
     else
         ui->textEdit->append("等待客户端连接,请再次发送....");
void send::on_pushButton_2_clicked()  //选择文件
        QString filePath = QFileDialog::getOpenFileName(this,"open","../");
            QFileInfo info(filePath);
            filename = info.fileName();
            size = info.size();
            file.setFileName(filePath);
            if( false== file.open(QIODevice::ReadOnly))
                ui->textEdit->append("文件打开路径有误....");
            else
                ui->textEdit->append("文件打开成功....");
        else
