开发板连接错误
1738|2
hsbjb|  楼主 | 2012-1-13 18:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己做的开发板,仿真机是XDS560PLUS
用JTAG口连接,连接时出现了以下错误
Trouble Reading Register:
Error 0x80002044/-275
Fatal Error during: Register, Initialization, Control,
This error was generated by TI\'s USCIF driver.
SC_ERR_SCN_POLL_BUSY <-275>
The utility or debugger has requested that a target DSP or micro-
controller be repeatedly accessed for a specific data or status value.
This has failed because the built-in limit for the maximum number
of attempts when polling the JTAG scan-path has been exceeded.
Sequence ID: 5
Error Code: -275
Error Class: 0x80002044
不知道是什么原因.....
之前还有2次连不上,都是电源方面引起的.....修改后,重连,连上了,但是再断电重连时就出现了以上的错误,之后就再也连不上了,不知是什么原因
秋天落叶| | 2012-1-13 18:36 | 只看该作者
检查一下JTAG口
dfsa| | 2012-1-13 22:51 | 只看该作者
开发板有问题
