Linux 0.00
162|0
无幻|  楼主 | 2018-9-29 07:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
linux, ov, TE, se, ST
/////////////////////////////////////////// boot.s
!    boot.s
! It then loads the system at 0x10000, using BIOS interrupts. Thereafter
! it disables all interrupts, changes to protected mode, and calls the
BOOTSEG = 0x07c0
SYSSEG  = 0x1000            ! system loaded at 0x10000 (65536).
SYSLEN  = 17                ! sectors occupied.
entry start
start:
    jmpi    go,#BOOTSEG
go:    mov    ax,cs
    mov    ds,ax
    mov    ss,ax
    mov    sp,#0x400        ! arbitrary value >>512
! ok, we've written the message, now
load_system:
    mov    dx,#0x0000
    mov    cx,#0x0002
    mov    ax,#SYSSEG
    mov    es,ax
    xor    bx,bx
    mov    ax,#0x200+SYSLEN
    int     0x13
    jnc    ok_load
die:    jmp    die
! now we want to move to protected mode ...
ok_load:
    cli            ! no interrupts allowed !
    mov    ax, #SYSSEG
    mov    ds, ax
    xor    ax, ax
    mov    es, ax
    mov    cx, #0x2000
    sub    si,si
    sub    di,di
    rep
    movw
    mov    ax, #BOOTSEG
    mov    ds, ax
    lidt    idt_48        ! load idt with 0,0
    lgdt    gdt_48        ! load gdt with whatever appropriate
! absolute address 0x00000, in 32-bit protected mode.
    mov    ax,#0x0001    ! protected mode (PE) bit
    lmsw    ax        ! This is it!
    jmpi    0,8        ! jmp offset 0 of segment 8 (cs)
gdt:    .word    0,0,0,0        ! dummy
    .word    0x07FF        ! 8Mb - limit=2047 (2048*4096=8Mb)
    .word    0x0000        ! base address=0x00000
    .word    0x9A00        ! code read/exec
    .word    0x00C0        ! granularity=4096, 386
    .word    0x9200        ! data read/write
idt_48: .word    0        ! idt limit=0
    .word    0,0        ! idt base=0L
gdt_48: .word    0x7ff        ! gdt limit=2048, 256 GDT entries
    .word    0x7c00+gdt,0    ! gdt base = 07xxx
.org 510
    .word   0xAA55
/////////////////////////////////////////// end of boot.s
/////////////////////////////////////////// head.s
#  head.s contains the 32-bit startup code.
#  Two L3 task multitasking. The code of tasks are in kernel area,
#  just like the Linux. The kernel code is located at 0x10000.
SCRN_SEL    = 0x18
TSS0_SEL    = 0x20
LDT0_SEL    = 0x28
TSS1_SEL    = 0X30
LDT1_SEL    = 0x38
.text
startup_32:
    movl $0x10,%eax
    mov %ax,%ds
#    mov %ax,%es
    lss init_stack,%esp
# setup base fields of descriptors.
    call setup_idt
    call setup_gdt
    movl $0x10,%eax        # reload all the segment registers
    mov %ax,%ds        # after changing gdt.
    mov %ax,%es
    mov %ax,%fs
    mov %ax,%gs
    lss init_stack,%esp
# setup up timer 8253 chip.
    movb $0x36, %al
    movl $0x43, %edx
    outb %al, %dx
    movl $11930, %eax        # timer frequency 100 HZ
    movl $0x40, %edx
    outb %al, %dx
    movb %ah, %al
    outb %al, %dx
# setup timer & system call interrupt descriptors.
    movl $0x00080000, %eax
    movw $timer_interrupt, %ax
    movw $0x8E00, %dx
    movl $0x08, %ecx              # The PC default timer int.
    lea idt(,%ecx,8), %esi
    movl %eax,(%esi)
    movl %edx,4(%esi)
    movw $system_interrupt, %ax
    movw $0xef00, %dx
    movl $0x80, %ecx
    movl %eax,(%esi)
    movl %edx,4(%esi)
# unmask the timer interrupt.
#    movl $0x21, %edx
#    inb %dx, %al
#    andb $0xfe, %al
#    outb %al, %dx
# Move to user mode (task 0)
    pushfl
    andl $0xffffbfff, (%esp)
    popfl
    movl $TSS0_SEL, %eax
    ltr %ax
    movl $LDT0_SEL, %eax
    lldt %ax
    movl $0, current
    sti
    pushl $0x17
    pushl $init_stack
    pushfl
    pushl $0x0f
    pushl $task0
    iret
setup_gdt:
    lgdt lgdt_opcode
    ret
setup_idt:
    lea ignore_int,%edx
    movl $0x00080000,%eax
    movw %dx,%ax        /* selector = 0x0008 = cs */
    movw $0x8E00,%dx    /* interrupt gate - dpl=0, present */
    lea idt,%edi
    mov $256,%ecx
rp_sidt:
    movl %eax,(%edi)
    movl %edx,4(%edi)
    addl $8,%edi
    dec %ecx
    jne rp_sidt
    lidt lidt_opcode
    ret
write_char:
    push %gs
    pushl %ebx
#    pushl %eax
    mov $SCRN_SEL, %ebx
    mov %bx, %gs
    movl scr_loc, %bx
    shl $1, %ebx
    movb %al, %gs:(%ebx)
    shr $1, %ebx
    incl %ebx
    cmpl $2000, %ebx
    jb 1f
    movl $0, %ebx
1:    movl %ebx, scr_loc
#    popl %eax
    popl %ebx
    pop %gs
    ret
/* This is the default interrupt "handler" :-) */
.align 2
ignore_int:
    push %ds
    pushl %eax
    movl $0x10, %eax
    mov %ax, %ds
    movl $67, %eax            /* print 'C' */
    call write_char
    popl %eax
    pop %ds
    iret
/* Timer interrupt handler */
.align 2
timer_interrupt:
    push %ds
    pushl %eax
    movl $0x10, %eax
    mov %ax, %ds
    movb $0x20, %al
    outb %al, $0x20
    movl $1, %eax
    cmpl %eax, current
    je 1f
    movl %eax, current
    ljmp $TSS1_SEL, $0
    jmp 2f
1:    movl $0, current
    ljmp $TSS0_SEL, $0
2:    popl %eax
    pop %ds
    iret
/* system call handler */
.align 2
system_interrupt:
    push %ds
    pushl %edx
    pushl %ecx
    pushl %ebx
    pushl %eax
    movl $0x10, %edx
    mov %dx, %ds
    call write_char
    popl %eax
    popl %ebx
    popl %ecx
    popl %edx
    pop %ds
    iret
current:.long 0
scr_loc:.long 0
.align 2
lidt_opcode:
    .word 256*8-1        # idt contains 256 entries
    .long idt        # This will be rewrite by code.
lgdt_opcode:
    .word (end_gdt-gdt)-1    # so does gdt
    .long gdt        # This will be rewrite by code.
    .align 3
idt:    .fill 256,8,0        # idt is uninitialized
gdt:    .quad 0x0000000000000000    /* NULL descriptor */
    .quad 0x00c09a00000007ff    /* 8Mb 0x08, base = 0x00000 */
    .quad 0x00c09200000007ff    /* 8Mb 0x10 */
    .quad 0x00c0920b80000002    /* screen 0x18 - for display */
    .word 0x0068, tss0, 0xe900, 0x0    # TSS0 descr 0x20
    .word 0x0040, ldt0, 0xe200, 0x0    # LDT0 descr 0x28
    .word 0x0068, tss1, 0xe900, 0x0    # TSS1 descr 0x30
    .word 0x0040, ldt1, 0xe200, 0x0    # LDT1 descr 0x38
end_gdt:
    .fill 128,4,0
init_stack:                          # Will be used as user stack for task0.
    .long init_stack
    .word 0x10
.align 3
ldt0:    .quad 0x0000000000000000
    .quad 0x00c0fa00000003ff    # 0x0f, base = 0x00000
    .quad 0x00c0f200000003ff    # 0x17
tss0:    .long 0             /* back link */
    .long krn_stk0, 0x10        /* esp0, ss0 */
    .long 0, 0, 0, 0, 0        /* esp1, ss1, esp2, ss2, cr3 */
    .long 0, 0, 0, 0, 0        /* eip, eflags, eax, ecx, edx */
    .long 0, 0, 0, 0, 0        /* ebx esp, ebp, esi, edi */
    .long 0, 0, 0, 0, 0, 0         /* es, cs, ss, ds, fs, gs */
    .long LDT0_SEL, 0x8000000    /* ldt, trace bitmap */
    .fill 128,4,0
krn_stk0:
#    .long 0
.align 3
ldt1:    .quad 0x0000000000000000
tss1:    .long 0             /* back link */
    .long krn_stk1, 0x10        /* esp0, ss0 */
    .long task1, 0x200        /* eip, eflags */
    .long 0, 0, 0, 0        /* eax, ecx, edx, ebx */
    .long usr_stk1, 0, 0, 0        /* esp, ebp, esi, edi */
    .long 0x17,0x0f,0x17,0x17,0x17,0x17 /* es, cs, ss, ds, fs, gs */
    .long LDT1_SEL, 0x8000000    /* ldt, trace bitmap */
    .fill 128,4,0
krn_stk1:
task0:
    movl $0x17, %eax
    movw %ax, %ds
    movl $65, %al              /* print 'A' */
    int $0x80
    movl $0xfff, %ecx
1:    loop 1b
    jmp task0
task1:
    movl $0x17, %eax
    movw %ax, %ds
    movl $66, %al              /* print 'B' */
    int $0x80
    movl $0xfff, %ecx
1:    loop 1b
    jmp task1
    .fill 128,4,0
usr_stk1:
