环形队列解决生产消费问题
308|0
 楼主| 第十代火影 发表于 2018-10-3 15:18 | 显示全部楼层 |阅读模式
se, TI, Queue, dc, ck
#include <math.h>
int n=2048,n1=2048,n2=2048;
  uint8_t Count=0;
  uint8_t f=0;
  int val=0;
void ADC_DATA_CALLBACK(uint32_t u32UserData)
  n=n1;
  n1=n2;
  n2=DrvADC_GetConversionData(1);
  if(n2-n>650)
   DrvGPIO_ClrBit(E_PORT2, E_PIN7);
  if(n-n2>650)
     DrvGPIO_SetBit(E_PORT2, E_PIN7);
/* val=abs(n2-n);
if((val>650)&&(Count==0))
   Count=1;
  else
   Count=0;
     if(Count==1)
     if(f)
       f=0;
     else
       f=1;
    DrvADC_StartConvert();
void time1_callback(uint32_t da)//定时器1专门作为闪烁使用
   DrvSYS_UnlockProtectedReg();
DrvWDT_Ioctl(E_WDT_IOC_RESET_TIMER,0);  //喂狗
      DrvSYS_LockProtectedReg();
void time0_callback(uint32_t da)//定时器0专门做采样工作和刷新屏幕显示
void initsys()
while(DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1)!=FALSE);//使能外部12MHZ晶振
DrvSYS_SelectPLLSource(E_SYS_EXTERNAL_12M);
DrvSYS_SetPLLMode(0);//pll正常
DrvSYS_UnlockProtectedReg();//关闭寄存器保护
DrvSYS_Open(50000000);//sys=12MHZ
DrvSYS_SelectHCLKSource(2);//pll
//while( DrvSYS_SelectHCLKSource(0) !=FALSE);//HCLK=12MHZ
DrvSYS_SetClockDivider(E_SYS_HCLK_DIV , 0);//HCLK1分频
while(DrvSYS_SelectSysTickSource(0)!=FALSE);//选择系统嘀嗒时钟源为外部12MHZ晶振
void initTMR0()
  DrvSYS_SetIPClock(E_SYS_TMR0_CLK,1); //使能始终
  DrvSYS_SelectIPClockSource(E_SYS_TMR0_CLKSRC,2 );//这个TIM0是接到APB总线,不可以用外部晶振,手册的是错误的,应该看下面的APBPCLK的时钟
  DrvTIMER_Init();
  DrvTIMER_Open(E_TMR0,1,E_PERIODIC_MODE); //100MS
  DrvTIMER_EnableInt(E_TMR0);
  DrvTIMER_SetTimerEvent(E_TMR0, 2, time0_callback, 1);//1s
  DrvTIMER_Start(E_TMR0);
  DrvSYS_SetIPClock(E_SYS_TMR1_CLK,1); //使能始终
  DrvSYS_SelectIPClockSource(E_SYS_TMR1_CLKSRC,2 );//这个TIM0是接到APB总线,不可以用外部晶振,手册的是错误的,应该看下面的APBPCLK的时钟
  DrvTIMER_Open(E_TMR1,10,E_PERIODIC_MODE); //100MS
  DrvTIMER_EnableInt(E_TMR1);
  DrvTIMER_SetTimerEvent(E_TMR1, 2, time1_callback, 1);//0.5s
  DrvTIMER_Start(E_TMR1);
  void init_ADC()
   /*Initialize ADC*/
DrvGPIO_InitFunction(E_FUNC_ADC1 );
    DrvADC_Open(ADC_SINGLE_END, ADC_CONTINUOUS_OP, 0x02, EXTERNAL_12MHZ, 59);
DrvADC_EnableADCInt(ADC_DATA_CALLBACK,0);
#include <stdio.h>
#include <string.h>
#include "SqQueue.h"
status InitQueue(SqQueue *Q,QElemType *Q_BUF)
   Q->base=Q_BUF;
   Q->front=0;
   Q->rear=0;
  return OK;
int QueueLength(SqQueue *Q)
return ((Q->rear-Q->front+MAXQSIZE) % MAXQSIZE);
status EnQueue(SqQueue *Q,QElemType *e)
if(((Q->rear+1) % MAXQSIZE) == Q->front) return ERROR;
   Q->base[Q->rear] = *e;
   Q->rear = (Q->rear+1) % MAXQSIZE;
   return OK;
status DeQueue(SqQueue *Q,QElemType *e)
if(Q->front == Q->rear) return ERROR;
    *e = Q->base[Q->front] ;
Q->front = (Q->front+1) % MAXQSIZE;
   return OK;
#define MAXQSIZE 100
#define ERROR       0
#define OK        1
#define  status unsigned char
#define  QElemType unsigned char
typedef struct{
QElemType *base;
unsigned char front;
unsigned char rear;
}SqQueue;
status InitQueue(SqQueue *Q,QElemType *Q_BUF);
int QueueLength(SqQueue *Q);
status EnQueue(SqQueue *Q,QElemType *e);
status DeQueue(SqQueue *Q,QElemType *e) ;复制代码
