EXAMPLE: a baud rate of 4800 baud is required with a crystal frequency of
32,768 Hz. This is necessary because the UART also has to run during low power
mode 3. With only the ACLK available, the theoretical division factor—the
truncated value is the content of baud-rate register UBR (UBR1/UBR0)—is:
UBR
32768
4800
6.82667
