u-boot移植步骤之支持网络和 nand flash操作命令
283|0
 楼主| 社畜一枚 发表于 2018-10-4 09:36 | 显示全部楼层 |阅读模式
1 添加网络命令
在include/configs/gec2410.h
只要在
#define CONFIG_COMMANDS
添加定义
CFG_CMD_NET |\
CFG_CMD_PING |\
就可以了
说明:include/configs/gec2410.h
文件是与开发板相关的配置头文件。
2 支持nand flash启动和读写
(1) 支持从nand flash 启动
a 添加nandflash寄存器的定义
修改include/configs/gec2410.h文件,
添加如下内容:
/* * Nandflash Boot */
#define CONFIG_S3C2410_NAND_BOOT 1
#define STACK_BASE    0x33f00000
#define STACK_SIZE    0x8000
#define UBOOT_RAM_BASE    0x33f80000
/* NAND Flash Controller */
#define NAND_CTL_BASE            0x4E000000
#define bINT_CTL(Nb)        __REG(INT_CTL_BASE + (Nb))
/* Offset */
#define oNFCONF               0x00
#define oNFCMD                0x04
#define oNFADDR               0x08
#define oNFDATA               0x0c
#define oNFSTAT               0x10
#define oNFECC                0x14
b 在start.S加入搬运代码
修改cpu/arm920t/start.S文件
在ldr pc, _start_armboot之前加入:
#ifdef    CONFIG_S3C2410_NAND_BOOT
bl    copy_myself
@ jump to ram
ldr   r1, =on_the_ram
add  pc, r1, #0
nop
nop
1:    b     1b          @ infinite loop on_the_ram:
#endif
在_start_armboot: .word start_armboot之后加入:
copy_myself:  mov r10, lr
@ reset NAND
mov r1, #NAND_CTL_BASE
ldr   r2, =0xf830           @ initial value
str   r2, [r1, #oNFCONF]
ldr   r2, [r1, #oNFCONF]
bic  r2, r2, #0x800              @ enable chip
mov r2, #0xff         @ RESET command
strb r2, [r1, #oNFCMD]
mov r3, #0                   @ wait
1:add  r3, r3, #0x1
cmp r3, #0xa
blt   1b
2:ldr   r2, [r1, #oNFSTAT]      @ wait ready
tst    r2, #0x1
beq  2b
orr  r2, r2, #0x800              @ disable chip
@ get read to call C functions (for nand_read())
ldr   sp, DW_STACK_START       @ setup stack pointer
mov fp, #0                    @ no previous frame, so fp=0
@ copy vivi to RAM
ldr   r0, =UBOOT_RAM_BASE
mov     r1, #0x0
mov r2, #0x20000
bl    nand_read_ll
tst    r0, #0x0
beq  ok_nand_read
#ifdef CONFIG_DEBUG_LL
bad_nand_read:
ldr   r0, STR_FAIL
ldr   r1, SerBase
bl    PrintWord1:b     1b          @ infinite loop
#endif
ok_nand_read:
ldr   r0, STR_OK
ldr   r1, SerBase
bl    PrintWord
#endif
@ verify
mov r0, #0
ldr   r1, =UBOOT_RAM_BASE
mov r2, #0x400     @ 4 bytes * 1024 = 4K-bytesgo_next:
ldr   r3, [r0], #4
ldr   r4, [r1], #4
teq   r3, r4
bne  notmatch
subs r2, r2, #4
beq  done_nand_read
bne  go_next
notmatch:
sub  r0, r0, #4
ldr   r1, SerBase
bl    PrintHexWord
ldr   r0, STR_FAIL
ldr   r1, SerBase
bl    PrintWord
#endif
1:b     1bdone_nand_read:
ldr   r0, STR_OK
ldr   r1, SerBase
bl    PrintWord
#endif
mov pc, r10
@ clear memory
@ r0: start address
@ r1: length  mem_clear:
mov r2, #0
mov r3, r2
mov r4, r2
mov r5, r2
mov r6, r2
mov r7, r2
mov r8, r2
mov r9, r2
clear_loop:
stmia      r0!, {r2-r9}
subs r1, r1, #(8 * 4)
bne  clear_loop
mov pc, lr
#endif @ CONFIG_S3C2410_NAND_BOOT
在文件的最后加入如下,堆栈地址:
   .align     2
DW_STACK_START:
.word      STACK_BASE+STACK_SIZE-4
c 添加nand_read_ll函数的实现在board/gec2410/建立nand_read.c,
加入如下内容(copy from vivi):
#include <config.h>
#define __REGb(x) (*(volatile unsigned char *)(x))
#define __REGi(x) (*(volatile unsigned int *)(x))
#define NF_BASE  0x4e000000#define NFCONF  __REGi(NF_BASE + 0x0)
#define NFCMD  __REGb(NF_BASE + 0x4)
#define NFADDR  __REGb(NF_BASE + 0x8)
#define NFDATA  __REGb(NF_BASE + 0xc)
#define NFSTAT  __REGb(NF_BASE + 0x10)
#define BUSY 1
inline void wait_idle(void)
int i;
while(!(NFSTAT & BUSY))
for(i=0; i<10; i++);
#define NAND_SECTOR_SIZE 512
#define NAND_BLOCK_MASK  (NAND_SECTOR_SIZE - 1)
/* low level nand read function */
intnand_read_ll(unsigned char *buf, unsigned long start_addr, int size)
int i, j;
if ((start_addr & NAND_BLOCK_MASK) || (size & NAND_BLOCK_MASK))
return -1;
/* invalid alignment */
/* chip Enable */
NFCONF &= ~0x800;
for(i=start_addr;
i < (start_addr + size);)
     /* READ0 */
    NFCMD = 0;
   /* Write Address */
    NFADDR = i & 0xff;
    NFADDR = (i >> 9) & 0xff;
   NFADDR = (i >> 17) & 0xff;
   NFADDR = (i >> 25) & 0xff;
   wait_idle();
   for(j=0; j < NAND_SECTOR_SIZE; j++, i++)
          *buf = (NFDATA & 0xff);
          buf++;
/* chip Disable */
NFCONF |= 0x800;
/* chip disable */
  return 0;
修改board/gec2410/Makefile为
OBJS := gec2410.o flash.o nand_read.o
以上步骤就可以把u-boot烧写到nandflash上了
(2) 支持nand flash操作命令
a 在/include/configs/gec2410.h
文件中添加宏定义
#define CONFIG_COMMANDS添加定义
CFG_CMD_NAND
CFG_CMD_ENV
b 定义环境变量宏
#define   CFG_ENV_IS_IN_FLASH 1
#define CFG_ENV_SIZE           0x10000
/* Total Size of Environment Sector */
改为
#define   CFG_ENV_IS_IN_NAND  1
#define CFG_ENV_OFFSET                   0x030000
#define CFG_NAND_BASE    0x4E000000
#define CMD_SAVEENV
#define CFG_NAND_LEGACY
/*set env*/
#define CFG_MONITOR_BASE PHYS_SDRAM_1
c 修改common/cmd_nand.c文件,
添加nand flash初始化函数添加
#define rNFCONF (*(volatile unsigned *)0x4E000000)
#define rNFCMD (*(volatile unsigned *)0x4E000004)
#define rNFADDR (*(volatile unsigned *)0x4E000008)
#define rNFDATA (*(volatile unsigned *)0x4E00000C)
#define rNFSTAT (*(volatile unsigned *)0x4E000010)
#define rNFECC (*(volatile unsigned *)0x4E000014)
#define CFG_MAX_NAND_DEVICE 1
/* Max number of NAND devices */
#define SECTORSIZE 512
#define ADDR_COLUMN 1
#define ADDR_PAGE 2
#define ADDR_COLUMN_PAGE 3
#define NAND_ChipID_UNKNOWN  0x00
#define NAND_MAX_FLOORS 1
#define NAND_MAX_CHIPS 1
#define NAND_WAIT_READY(nand) {while(!(rNFSTAT&(1<<0)));}
#define NAND_DISABLE_CE(nand) {rNFCONF|=(1<<11);}
#define NAND_ENABLE_CE(nand) {rNFCONF&=~(1<<11);}
#define WRITE_NAND_COMMAND(d , adr) {rNFCMD=d;}
#define WRITE_NAND_ADDRESS(d, adr) {rNFADDR=d;}
#define WRITE_NAND(d , adr) {rNFDATA=d;}
#define READ_NAND(adr)         (rNFDATA)
/* the following functions are NOP's because S3C24X0 handles this in hardware */
#define NAND_CTL_CLRALE(nandptr)
#define NAND_CTL_SETALE(nandptr)
#define NAND_CTL_CLRCLE(nandptr)
#define NAND_CTL_SETCLE(nandptr)
#define CONFIG_MTD_NAND_VERIFY_WRITE 1
添加nand_init()函数的实现
void nand_init(void)
int i;
unsigned long j;
rNFCONF=(1<<15)|(1<<14)|(1<<13)|(1<<12)|(1<<11)|(0<<8)|(3<<4)|(0<<0);
rNFCONF=rNFCONF&~(1<<11);
rNFCMD=0xff;
for(i=0;i<10;i++);
rNFCONF=rNFCONF|(1<<11);
  j=nand_probe(0x4e000000);
printf("nand flash : %4lu MB\n",j>>20);
d 在nand_probe函数中添加一行
#endif
oob_config.badblock_pos = 5;
nand_dev_desc[0].ChipID = 0x00;
uboot移植完成!
