Linux I2C子系统分析-I2C设备驱动
305|0
 楼主| 白板就是这个 发表于 2018-10-5 13:30 | 显示全部楼层 |阅读模式
接下来以一个实际的例子来看I2C设备驱动,就以drivers/i2c/i2c-dev.c为例。先看它的初始化和注销函数static int __init i2c_dev_init(void)
int res; printk(KERN_INFO "i2c /dev entries driver\n"); res = register_chrdev(I2C_MAJOR, "i2c", &i2cdev_fops);
if (res)
  goto out; i2c_dev_class = class_create(THIS_MODULE, "i2c-dev");
if (IS_ERR(i2c_dev_class)) {
  res = PTR_ERR(i2c_dev_class);
  goto out_unreg_chrdev;
} res = i2c_add_driver(&i2cdev_driver);
if (res)
  goto out_unreg_class; return 0;out_unreg_class:
class_destroy(i2c_dev_class);
out_unreg_chrdev:
unregister_chrdev(I2C_MAJOR, "i2c");
out:
printk(KERN_ERR "%s: Driver Initialisation failed\n", __FILE__);
return res;
}static void __exit i2c_dev_exit(void)
i2c_del_driver(&i2cdev_driver);
unregister_chrdev(I2C_MAJOR,"i2c");
}首先调用register_chrdev注册了一个字符设备,这是老的字符驱动注册方式。然后到了接下来的主角,i2c_add_driver,在I2C子系统中,I2C设备驱动就是采用这个函数注册,注销一个I2C设备驱动使用下面的i2c_del_driver函数,那就具体看看这个I2C设备驱动注册函数。static inline int i2c_add_driver(struct i2c_driver *driver)
return i2c_register_driver(THIS_MODULE, driver);
int i2c_register_driver(struct module *owner, struct i2c_driver *driver)
int res; /* Can't register until after driver model init */
if (unlikely(WARN_ON(!i2c_bus_type.p)))
  return -EAGAIN; /* add the driver to the list of i2c drivers in the driver core */
driver->driver.owner = owner;
driver->driver.bus = &i2c_bus_type; /*指定驱动的总线类型*/ /* When registration returns, the driver core
  * will have called probe() for all matching-but-unbound devices.
res = driver_register(&driver->driver); /*注册驱动*/
if (res)
  return res; pr_debug("i2c-core: driver [%s] registered\n", driver->driver.name); INIT_LIST_HEAD(&driver->clients);
/* Walk the adapters that are already present */
mutex_lock(&core_lock);
bus_for_each_dev(&i2c_bus_type, NULL, driver, __attach_adapter);
mutex_unlock(&core_lock); return 0;
}再来看看i2c设备驱动注销函数void i2c_del_driver(struct i2c_driver *driver)
bus_for_each_dev(&i2c_bus_type, NULL, driver, __detach_adapter);
mutex_unlock(&core_lock); driver_unregister(&driver->driver);
pr_debug("i2c-core: driver [%s] unregistered\n", driver->driver.name);
}也没什么,最后调用的就是驱动的注销函数driver_unregister函数。
来看传递给注册和注销i2c驱动函数的参数什么,i2cdev_driver它是structi2c_driver结构类型,i2c设备驱动就是使用这个结构类型描述,这个结构类型定义在include/linux/i2c.hstruct i2c_driver {
unsigned int class; /* Notifies the driver that a new bus has appeared or is about to be
  * removed. You should avoid using this if you can, it will probably
  * be removed in a near future.
int (*attach_adapter)(struct i2c_adapter *);
int (*detach_adapter)(struct i2c_adapter *); /* Standard driver model interfaces */
int (*probe)(struct i2c_client *, const struct i2c_device_id *);
int (*remove)(struct i2c_client *); /* driver model interfaces that don't relate to enumeration  */
void (*shutdown)(struct i2c_client *);
int (*suspend)(struct i2c_client *, pm_message_t mesg);
int (*resume)(struct i2c_client *); /* a ioctl like command that can be used to perform specific functions
  * with the device.
int (*command)(struct i2c_client *client, unsigned int cmd, void *arg); struct device_driver driver;
const struct i2c_device_id *id_table; /* Device detection callback for automatic device creation */
int (*detect)(struct i2c_client *, int kind, struct i2c_board_info *);
const struct i2c_client_address_data *address_data;
struct list_head clients;
};来看i2c-dev.c中是怎么定义的static struct i2c_driver i2cdev_driver = {
.driver = {
  .name = "dev_driver",
.attach_adapter = i2cdev_attach_adapter,
.detach_adapter = i2cdev_detach_adapter,
};这是老的方式,所以它只是给attach_adapter和detach_adapter赋了值,由于这里是老的方式,所以我们也就不去具体看这个函数了,我们直接去看它的数据传输部分吧。static ssize_t i2cdev_read (struct file *file, char __user *buf, size_t count,
                            loff_t *offset)
char *tmp;
int ret; struct i2c_client *client = (struct i2c_client *)file->private_data; if (count > 8192)
  count = 8192; tmp = kmalloc(count,GFP_KERNEL);
if (tmp==NULL)
  return -ENOMEM; pr_debug("i2c-dev: i2c-%d reading %zu bytes.\n",
  iminor(file->f_path.dentry->d_inode), count); ret = i2c_master_recv(client,tmp,count);
if (ret >= 0)
  ret = copy_to_user(buf,tmp,count)?-EFAULT:ret;
kfree(tmp);
return ret;
}这是i2c设备读函数,我们看它是调用的i2c_master_recv函数去操作的,去看这个函数int i2c_master_recv(struct i2c_client *client, char *buf ,int count)
struct i2c_adapter *adap=client->adapter;
struct i2c_msg msg;
int ret; msg.addr = client->addr;
msg.flags = client->flags & I2C_M_TEN;
msg.flags |= I2C_M_RD;
msg.len = count;
msg.buf = buf; ret = i2c_transfer(adap, &msg, 1); /* If everything went ok (i.e. 1 msg transmitted), return #bytes
    transmitted, else error code. */
return (ret == 1) ? count : ret;
}i2c设备写函数static ssize_t i2cdev_write (struct file *file, const char __user *buf, size_t count,
                             loff_t *offset)
int ret;
char *tmp;
if (tmp==NULL)
  return -ENOMEM;
if (copy_from_user(tmp,buf,count)) {
  kfree(tmp);
  return -EFAULT;
} pr_debug("i2c-dev: i2c-%d writing %zu bytes.\n",
  iminor(file->f_path.dentry->d_inode), count); ret = i2c_master_send(client,tmp,count);
kfree(tmp);
return ret;
int i2c_master_send(struct i2c_client *client,const char *buf ,int count)
int ret;
struct i2c_msg msg; msg.addr = client->addr;
msg.len = count;
msg.buf = (char *)buf; ret = i2c_transfer(adap, &msg, 1); /* If everything went ok (i.e. 1 msg transmitted), return #bytes
}这两个函数最终都是调用的i2c_transfer函数去完成数据的传输,只是他们的msg的flags不一样,读操作的flags要加上I2C_M_RD这个标志。
再看它们两个共同的i2c_transfer函数int i2c_transfer(struct i2c_adapter *adap, struct i2c_msg *msgs, int num)
unsigned long orig_jiffies;
int ret, try; /* REVISIT the fault reporting model here is weak:
  *  - When we get an error after receiving N bytes from a slave,
  *    there is no way to report "N".
  *  - When we get a NAK after transmitting N bytes to a slave,
  *    there is no way to report "N" ... or to let the master
  *    continue executing the rest of this combined message, if
  *    that's the appropriate response.
  *  - When for example "num" is two and we successfully complete
  *    the first message but get an error part way through the
  *    second, it's unclear whether that should be reported as
  *    one (discarding status on the second message) or errno
  *    (discarding status on the first one).
  */ if (adap->algo->master_xfer) {
#ifdef DEBUG
  for (ret = 0; ret < num; ret++) {
   dev_dbg(&adap->dev, "master_xfer[%d] %c, addr=0x%02x, "
    "len=%d%s\n", ret, (msgs[ret].flags & I2C_M_RD)
    ? 'R' : 'W', msgs[ret].addr, msgs[ret].len,
    (msgs[ret].flags & I2C_M_RECV_LEN) ? "+" : "");
#endif  if (in_atomic() || irqs_disabled()) {
   ret = mutex_trylock(&adap->bus_lock);
   if (!ret)
    /* I2C activity is ongoing. */
    return -EAGAIN;
  } else {
   mutex_lock_nested(&adap->bus_lock, adap->level);
  }  /* Retry automatically on arbitration loss */
  orig_jiffies = jiffies;
  for (ret = 0, try = 0; try <= adap->retries; try++) {
   ret = adap->algo->master_xfer(adap, msgs, num);
   if (ret != -EAGAIN)
    break;
   if (time_after(jiffies, orig_jiffies + adap->timeout))
    break;
  mutex_unlock(&adap->bus_lock);  return ret;
} else {
  dev_dbg(&adap->dev, "I2C level transfers not supported\n");
  return -EOPNOTSUPP;
}我们看就是调用总线的master_xfer方法,我们在前面分析使用gpio模拟i2c总线时,看过这样一句 .master_xfer =bit_xfer, ,所以最终调用的是这个函数来完成数据传输。使用i2c_master_recv和i2c_master_send函数一次只能传输一个msg,由于它一次只能传输一个msg,所以它的传输方向不能改变,也就是一次只能完成读或写操作,并且读操作时还不能传递设备的基地址,所以通常是不会用这两个函数的,直接的做法时,构造两个msg,一个msg的数据为操作设备基地址,另外一个msg才是我们真正要读写的数据,最后调用i2c_transfer函数去完成数据的传送。
