临时中断irq测试tasklet和workqueue的版本
259|0
王将|  楼主 | 2018-10-5 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Queue, ev, ic, ST, vi
#ifndef __IRQ_H__
#define __IRQ_H_
#include <linux/fs.h>
#include <linux/semaphore.h>
#include <linux/wait.h>
#include <linux/cdev.h>
#define IRQ_MAJOR 0
#define DEVICE_NAME "key"
struct key{
//    struct cdev cdev;
//    struct semaphore* sem;
    const char* name;
    unsigned long flags;
    unsigned int irq;
    unsigned int val;
struct irq_dev{
    struct cdev cdev;
    struct semaphore sem;
    wait_queue_head_t key_queue;
    struct key* pkey;
#endif
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/device.h>
#include <mach/map.h>
#include <mach/regs-gpio.h>
#include <mach/gpio-bank-n.h>
#include <asm/io.h>
#include <asm/uaccess.h>
#include <linux/sched.h>
#include <linux/interrupt.h>
#include <mach/irqs.h>
#include <linux/irq.h>
#include <linux/time.h>
#include <linux/delay.h>
#include <linux/workqueue.h>
#include "irq.h"
#define IRQ_DEBUG
#ifdef IRQ_DEBUG
#define dprintk(fmt, arg...)     printk("###IRQ DEBUG###%s():"fmt, __func__, ##arg)
#else
#endif
static int irq_major = IRQ_MAJOR;
struct irq_dev* irq;
static struct key key={
    .name = "key0",
    .flags = IRQ_TYPE_EDGE_RISING,
    .irq = IRQ_EINT(0),
    .val = 0,
void tasklet(unsigned long data)
    dprintk("data=%d\n", data);
    dprintk("key!\n");
    dprintk("S3C64XX_EINT0PEND=0x%x\n", __raw_readl(S3C64XX_EINT0PEND));
    dprintk("S3C64XX_EINT0CON0=0x%x\n", __raw_readl(S3C64XX_EINT0CON0));
    dprintk("S3C64XX_EINT0CON1=0x%x\n", __raw_readl(S3C64XX_EINT0CON1));
    dprintk("S3C64XX_EINT0FLTCON0=0x%x\n", __raw_readl(S3C64XX_EINT0FLTCON0));
    dprintk("S3C64XX_EINT0FLTCON1=0x%x\n", __raw_readl(S3C64XX_EINT0FLTCON1));
    dprintk("S3C64XX_EINT0FLTCON2=0x%x\n", __raw_readl(S3C64XX_EINT0FLTCON2));
    dprintk("S3C64XX_EINT0FLTCON3=0x%x\n", __raw_readl(S3C64XX_EINT0FLTCON3));
    dprintk("S3C64XX_EINT0MASK=0x%x\n", __raw_readl(S3C64XX_EINT0MASK));
    dprintk("S3C64XX_SERVICEPEND=0x%x\n", __raw_readl(S3C64XX_SERVICEPEND));
    dprintk("VIC0IRQSTATUS=0x%x\n", __raw_readl(VA_VIC0));
    dprintk("VIC0FIQSTATUS=0x%x\n", __raw_readl(VA_VIC0 + 0x4));
    dprintk("VIC0VECTADDR0 =0x%x\n", __raw_readl(VA_VIC0 + 0x100));
    dprintk("VICxADDRESS =0x%x\n", __raw_readl(VA_VIC0 + 0xf00));
    dprintk("1:%x 2:%x 3:%x 4:%x\n", __raw_readl(VA_VIC0+0x008), __raw_readl(VA_VIC0+0x00c),
                                        __raw_readl(VA_VIC0+0x010),__raw_readl(VA_VIC0+0x014));
DECLARE_TASKLET(irq_tasklet, tasklet, 0);
static struct work_struct key_work;
void work_func(struct work_struct* data)
    dprintk("work");
static irqreturn_t interrupt_handler(int irq, void* dev)
    writel(IRQ_EINT0_3, S3C64XX_EINT0PEND);  //clear interrupt flag
    tasklet_schedule(&irq_tasklet);
    return IRQ_HANDLED;
static irqreturn_t interrupt_handl(int irq, void* dev)
//    writel(IRQ_EINT0_3, S3C64XX_EINT0PEND);  //clear interrupt flag
    schedule_work(&key_work);
    return IRQ_HANDLED;
static int irq_open(struct inode* inode, struct file* filp)
    int err;
    dprintk("open!\n");
    filp->private_data = irq;
    err = request_irq(irq->pkey->irq, interrupt_handler, irq->pkey->flags,
                               irq->pkey->name, (void*)irq);
    if(err)
        free_irq(irq->pkey->irq, (void*)irq);
    err = request_irq(IRQ_EINT(1), interrupt_handl, IRQ_TYPE_EDGE_FALLING,
                               "key1", NULL);
    if(err)
        free_irq(IRQ_EINT(1), NULL);
    return 0;
static int irq_close(struct inode* inode, struct file* filp)
    dprintk("close!\n");
    return 0;
static ssize_t irq_read(struct file* filp, char __user* buff, size_t count, loff_t* offp)
    struct irq_dev* irq = filp->private_data;
    if(down_interruptible(&irq->sem))
        return -ERESTARTSYS;
note:此处要实现阻塞,并在中断服务程序唤醒或者在中断服务中发出一个信号。
    up(&irq->sem);
    return count;
static const struct file_operations irq_fops = {
    .open           = irq_open,
    .release        = irq_close,
    .read              = irq_read,
static void irq_setup_cdev(struct irq_dev* dev, int index)
    int err, devno = MKDEV(irq_major, 0);
    cdev_init(&dev->cdev, &irq_fops);
    dev->cdev.owner = THIS_MODULE;
    err = cdev_add(&dev->cdev, devno, 1);
    if(err)
        printk("error add cdev!\n");
struct class* irq_class;
int irq_init(void)
    int result;
    dev_t devno = MKDEV(irq_major, 0);
    if(irq_major)
        result = register_chrdev_region(devno, 1, DEVICE_NAME);
    else{
        dprintk("alloc_chrdev_region\n");
        result = alloc_chrdev_region(&devno, 0, 1, DEVICE_NAME);
        irq_major = MAJOR(devno);
    if(result < 0)
        return result;
    irq = kmalloc(sizeof(struct irq_dev), GFP_KERNEL);
    if(!irq){
        result = -ENOMEM;
        goto malloc_error;
    memset(irq, 0, sizeof(struct irq_dev));
    irq_setup_cdev(irq, 0);
    init_MUTEX(&irq->sem);
    init_waitqueue_head(&irq->key_queue);
    irq->pkey = &key;
    INIT_WORK(&key_work, work_func);
    irq_class = class_create(THIS_MODULE, "irq_class");
    device_create(irq_class, NULL, MKDEV(irq_major, 0), NULL, "%s", DEVICE_NAME);
    return 0;
malloc_error:
    unregister_chrdev_region(devno, 1);
    return result;
void irq_exit(void)
    cdev_del(&irq->cdev);
    device_destroy(irq_class, MKDEV(irq_major, 0));
    class_destroy(irq_class);
    kfree(irq);
    unregister_chrdev_region(MKDEV(irq_major, 0), 1);
module_init(irq_init);
module_exit(irq_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("jf.s <jingfeng.shi@emdoor.com>");
这是一个临时irq测试tasklet和workqueue的版本,并测试了s3c6410的vic reg ,6410的vic reg貌似问题一大堆,等双休日再研究研究。
