求助
3375|1
 楼主| 去耦滤波 发表于 2012-1-21 00:24 | 显示全部楼层 |阅读模式
ce, code, BLE, AN, se
在程序中用了sprintf函数后,编译没有错,但下载时出现以下错误提示,求解释。Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE. Unable to place 77 block(s) (0x1cec byte(s) total) in 0x754 byte(s) of memory. The problem occurred while processing the segment placement command "-P(CODE)CODE=F800-FFDF", where at the moment of placement the available memory ranges were "CODE:f88c-ffdf"
u880 发表于 2012-1-21 00:34 | 显示全部楼层
没有见过
