定时器的问题
2414|16
yszong|  楼主 | 2012-1-24 17:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发现,将TIMER0配置成32位,非关联模式后,TIMER3:4运行正常,但是TIMER1:2不运行。
heweibig| | 2012-1-24 17:42 | 只看该作者
代码设置代码看看
yszong|  楼主 | 2012-1-24 17:43 | 只看该作者
稍等
yszong|  楼主 | 2012-1-24 17:45 | 只看该作者
uint32_t USTIMER0_init(void)
    // configure timer 0 for free run.
    // 32-bit unchained mode, timer3:4 /12 prescaler.
    // enable muxed pins as gpio outputs and disable all related interrupts.
    // would need to also setup the pinmux register to select the gpio
    // function of these pins in order to use as gpio.
//   TMR0->GPINT_GPEN = GPENO12 | GPENI12;
//  TMR0->GPDATA_GPDIR = GPDIRO12 | GPDIRI12;
   // stop and reset timer.
   TMR0->TGCR = 0x00000000;
   TMR0->TCR = 0x00000000;
   // disable interrupts and set emulation to free run.
   TMR0->INTCTLSTAT = 0;
   SETBIT(TMR0->EMUMGT, SOFT | FREE);
   // config timer0 in 32-bit unchained mode.
   // remove timer0 - 3:4 from reset.
   SETBIT(TMR0->TGCR, PRESCALER(TIMER_DIV - 1) | TIMMODE_32BIT_UNCHAINED /*| TIM34RS*/ );
   // init timer0 - 1:2 period....use full range of counter.
   TMR0->TIM34 = 0x00000000;
   TMR0->PRD34 = 0x00000000;
// TMR0->PRD34 = 0xFFFFFFFF;
   TMR0->TIM12 = 0x00000000;
   TMR0->PRD12 = 0x00000000;
   // start timer0 - 3:4.
// SETBIT(TMR0->TCR, ENAMODE34_CONT);
   return (ERR_NO_ERROR);
void USTIMER0_delay(uint32_t in_delay)
    uint32_t regData;
#if 0
    // stop the timer, clear int stat, and clear timer value.
    CLRBIT(TMR0->TGCR, TIM34RS);
    SETBIT(TMR0->INTCTLSTAT, PRDINTSTAT34);
    // setup compare time.
    TMR0->PRD34 = TICKS_PER_US * in_delay;
    // start timer1 - 3:4 to run once up to the period.
    SETBIT(TMR0->TCR, ENAMODE34_ONETIME);
    SETBIT(TMR0->TGCR, TIM34RS);
    // wait for the signal that we have hit our period.
    while (!CHKBIT(TMR0->INTCTLSTAT, PRDINTSTAT34));
#else
    CLRBIT(TMR0->TGCR, TIM12RS);
    SETBIT(TMR0->INTCTLSTAT, PRDINTSTAT12);
    TMR0->PRD12 = TICKS_PER_US * in_delay;
    CLRBIT(TMR0->TCR,CLKSRC12);
    CLRBIT(TMR0->TCR,TIEN12);
    SETBIT(TMR0->TCR, ENAMODE12_ONETIME);
    SETBIT(TMR0->TGCR, TIM12RS);
    while (!CHKBIT(TMR0->INTCTLSTAT, PRDINTSTAT12));
#endif
主函数
main()
    USTIMER0_init();
    printf("the timer0 test start\n" );
    USTIMER0_delay(100);
    printf("the timer0 test end\n");
jlyuan| | 2012-1-24 17:46 | 只看该作者
如果使用timer3:4来实现,这个测试函数就可以走完吗?
yszong|  楼主 | 2012-1-24 22:52 | 只看该作者
可以走完
wuhany| | 2012-1-24 22:53 | 只看该作者
用timer1:2来做呢
yszong|  楼主 | 2012-1-24 22:55 | 只看该作者
不行
yszong|  楼主 | 2012-1-24 22:56 | 只看该作者
根据TI,定时器的 资料上配置了内部时钟源,禁止了内部时钟源开关就是始终不往下运行!
spark周| | 2012-1-24 22:59 | 只看该作者
还需要配置什么吧
午夜粪车| | 2012-1-24 22:59 | 只看该作者
检查Linux启动了没有
zhanghqi| | 2012-1-24 23:01 | 只看该作者
timer1:2中的一个被Linux当系统定时器用了
另一个在内核中好像是被Ban了。
huangchui| | 2012-1-24 23:03 | 只看该作者
把这个定时器设置为DSP使用
yszong|  楼主 | 2012-1-24 23:12 | 只看该作者
好了!
yszong|  楼主 | 2012-1-24 23:14 | 只看该作者
我的DSP端软件是裸跑的!
结贴了
