ADC10
3020|5
 楼主| acer4736 发表于 2012-1-27 23:28 | 显示全部楼层 |阅读模式
msp430g2553,有ADC10,要侧A7和A6的电压,然后分别读出值,单独测都行,两个一起测的话要怎么设置~?
ic开发者 发表于 2012-1-27 23:40 | 显示全部楼层
hold住 发表于 2012-1-28 00:08 | 显示全部楼层
没用过
简单生活 发表于 2012-1-30 18:21 | 显示全部楼层
RE: ADC10
可将ADC10设置为Single Sequence 模式.
如下为对A2,A1,A0连续读取的例子,可参考修改.
简单生活 发表于 2012-1-30 18:23 | 显示全部楼层
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL1 = INCH_3 + CONSEQ_1;            // A3/A2/A1, single sequence
  ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
  ADC10DTC1 = 0x03;                         // 3 conversions
  ADC10AE0 |= 0x0E;                         // P1.3,2,1 ADC10 option select
  P1DIR |= 0x01;                            // Set P1.0 output
  for (;;)
    ADC10CTL0 &= ~ENC;
    while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
    ADC10SA = 0x200;                        // Data buffer start
    P1OUT |= 0x01;                          // P1.0 = 1
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    P1OUT &= ~0x01;                         // P1.0 = 0
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
peter_zheng 发表于 2012-1-31 00:52 | 显示全部楼层
轮询测试2个通道,从A6开始,A7结束
