[技术求助] 问DAC7573里的LDAC引脚的作用是啥?
505|9
 楼主| jiaxw 发表于 2020-10-14 21:22 | 显示全部楼层 |阅读模式
 楼主| jiaxw 发表于 2020-10-14 21:26 | 显示全部楼层
该如何连接?
zhenykun 发表于 2020-10-14 21:30 | 显示全部楼层
LDAC Functionality
Depending on the control byte, DACs are synchronously updated on the falling edge of the acknowledge signal that follows LS byte. The LDAC pin is required only when an external timing signal is used to update all the channels of the DAC asynchronously. LDAC is a positive edge triggered asynchronous input that allows four DAC output voltages to be updated simultaneously with temporary register data. The LDAC trigger should only be used after the buffer's temporary registers are properly updated through software.
 楼主| jiaxw 发表于 2020-10-14 21:34 | 显示全部楼层
什么意思啊
dengdc 发表于 2020-10-14 21:37 | 显示全部楼层
简单地说: 在缓冲模式下, 通过 LDAC 引脚, 通知 DAC 芯片更新输出.
zhaoxqi 发表于 2020-10-14 21:44 | 显示全部楼层
LOAD dac的缩写啊,装载DAC值
wyjie 发表于 2020-10-14 21:47 | 显示全部楼层
wyjie 发表于 2020-10-14 21:51 | 显示全部楼层
langgq 发表于 2020-10-14 21:55 | 显示全部楼层
看手册的介绍,是个同步更新的引脚,下降沿有效
 楼主| jiaxw 发表于 2020-10-14 21:59 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
