树莓派LoRaWAN网关默认的上行混合信道(8+1)可以修改吗
671|0
前言
树莓派LoRaWAN网关默认的上行混合信道(8+1)可以修改吗?答案是可以的。
比如RAK瑞科慧联的RAK树莓派LoRaWAN网关RAK7244C,US915/AU915频段,其默认上行混合信道(8+1)是可以修改的。只不过修改之后,部分信道不可用,但也可以将部分LoRaWAN节点的上行信道修改为其他信道、以解决网关上行信道网络拥堵的难题。
本文以US915/AU915频段的树莓派LoRaWAN网关为例,介绍如何修改其上行信道。
一、树莓派LoRaWAN网关的原本的US915频段上行信道
以下是RAK树莓派LoRaWAN网关RAK7244C为例,其原本的US915频段上行信道:
0,off,902300000,0,3;  1,off,902500000,0,3;  2,off,902700000,0,3;  3,off,902900000,0,3;  4,off,903100000,0,3;  5,off,903300000,0,3;  6,off,903500000,0,3;  7,off,903700000,0,3;  8,on,903900000,0,3;       9,on,904100000,0,3;       10,on,904300000,0,3;      11,on,904500000,0,3;
12,on,904700000,0,3; 13,on,904900000,0,3; 14,on,905100000,0,3; 15,on,905300000,0,3; 16,off,905500000,0,3; 17,off,905700000,0,3; 18,off,905900000,0,3; 19,off,906100000,0,3; 20,off,906300000,0,3; 21,off,906500000,0,3; 22,off,906700000,0,3; 23,off,906900000,0,3; 24,off,907100000,0,3; 25,off,907300000,0,3; 26,off,907500000,0,3; 27,off,907700000,0,3; 28,off,907900000,0,3; 29,off,908100000,0,3; 30,off,908300000,0,3; 31,off,908500000,0,3; 32,off,908700000,0,3; 33,off,908900000,0,3; 34,off,909100000,0,3; 35,off,909300000,0,3; 36,off,909500000,0,3; 37,off,909700000,0,3; 38,off,909900000,0,3; 39,off,910100000,0,3; 40,off,910300000,0,3; 41,off,910500000,0,3; 42,off,910700000,0,3; 43,off,910900000,0,3; 44,off,911100000,0,3; 45,off,911300000,0,3; 46,off,911500000,0,3; 47,off,911700000,0,3; 48,off,911900000,0,3; 49,off,912100000,0,3; 50,off,912300000,0,3; 51,off,912500000,0,3; 52,off,912700000,0,3; 53,off,912900000,0,3; 54,off,913100000,0,3; 55,off,913300000,0,3; 56,off,913500000,0,3; 57,off,913700000,0,3; 58,off,913900000,0,3; 59,off,914100000,0,3; 60,off,914300000,0,3;      61,off,914500000,0,3;      62,off,914700000,0,3;      63,off,914900000,0,3;
64,off,903000000,4,4; 65,on,904600000,4,4; 66,off,906200000,4,4; 67,off,907800000,4,4; 68,off,909400000,4,4;      69,off,911000000,4,4;      70,off,912600000,4,4;      71,off,914200000,4,4
比如网关US915频段默认混合信道为(8~15+65)即“8+1”组合,如上图橘色部分信道。按照此逻辑可以将混合信道修改为(0~7+64)或者(16~23+66)......等。
二、如何将上行信道从65信道修改为67信道?
现问是否可以将固定组合(8~15+65)改为(8~15+67),考虑65信道节点太多,部分节点使用67信道以降低信道拥堵?
答案是可以修改,但只有部分信道(4+1)可用。修改步骤如下:
1、通过修改radio 0将(8~15+65)信道修改为可以用的信道(12~15+67),因为修radio是为了是将65改为67同时与radio 0有关(8~11)的4个信道均不可用,见右下图2(标注部分)
修改前网关的上行信道(下图左)           修改后网关的上行信道(下图右)
备注:US/AU915频段,radio 0和radio 1都最大只能关联5个信道。本网关配置各关联4个信道,修改radio 0后与其关联的4个信道将不可用;若改为可用,也非8~11。
2、若在步骤1的基础上将radio 0 有关的信道修改为原来的(8~11)+67号信道(上图左),则radio 0的IF偏移量超标(±400000),网关的packet forward进程启动会报错 。
3、按步骤1修改后(12~15+67)信道可用:
网关通道为(12~15+67),使用信道15 join成功(下图3)。
图3  LoRaWAN网关使用信道15 join成功
4、网关通道为(12~15+67),使用信道67 join成功(下图4)。
图4  LoRaWAN网关使用信道67 join成功
结语
本文介绍了如何修改树莓派LoRaWAN网关的默认的上行信道,以使得部分LoRaWAN节点的上行信道修改为其他信道、以解决网关上行信道网络拥堵的难题。但需要注意的是,修改了默认上行信道的话,存在部分信道不可用的风险。
