STM32 I2C 硬件中断方式实现方法,带流程图
14833|33
 楼主| armrunc 发表于 2012-2-1 11:30 | 显示全部楼层 |阅读模式
流程图如下:
I2C interrupt
I2C interrupt
yinyangdianzi 发表于 2012-2-1 11:34 | 显示全部楼层
是你啊,问题还没解决啊,,新年好,,,,
 楼主| armrunc 发表于 2012-2-1 11:34 | 显示全部楼层
其实现代码如下:
  * @brief  This function handles I2C1 Event interrupt request, tx, rx
  *         buffer and number of bytes will be changed.
  * @param  None
  * @retval None
void I2C1_EV_IRQHandler(void)
#ifdef ARC_I2C_IRQ
    uint32_t i2cEvent;
    I2C_param_struct __IO *pI2C_param;
    pI2C_param = ARC_get_I2C_param();
    i2cEvent = I2C_GetLastEvent(I2C1);
    switch (i2cEvent)
        case I2C_EVENT_MASTER_MODE_SELECT:/* EV5 */
            if(pI2C_param->I2C_DIRECTION == ARC_I2C_DIRECTION_TX)
                I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Transmitter);
            else
                I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Receiver);
            break;
        /* Master Transmitter -------------------------------------------------------*/
        case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
            I2C_SendData(I2C1, pI2C_param->SubAddr);
            if(pI2C_param->TxNumOfBytes == 0)
                I2C_ITConfig(I2C1, I2C_IT_BUF, DISABLE);
            break;
        case I2C_EVENT_MASTER_BYTE_TRANSMITTING:  /* Without BTF, EV8 */
            if(pI2C_param->TX_I2C_Index < pI2C_param->TxNumOfBytes)
                I2C_SendData(I2C1, pI2C_param->TxData[pI2C_param->TX_I2C_Index++]);
            else
            break;
        case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* With BTF EV8-2 */
           if(pI2C_param->TX_Generate_stop == 1)
             I2C_GenerateSTOP(I2C1, ENABLE);
             I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE);
           else
             pI2C_param->I2C_DIRECTION = ARC_I2C_DIRECTION_RX;
             I2C_ITConfig(I2C1, I2C_IT_BUF, ENABLE);
             I2C_GenerateSTART(I2C1, ENABLE);
           break;
        /* Master Receiver -------------------------------------------------------*/
        case I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED:
            if(pI2C_param->RX_I2C_Index == (pI2C_param->RxNumOfBytes - 1))
                I2C_AcknowledgeConfig(I2C1, DISABLE);
            break;
        case I2C_EVENT_MASTER_BYTE_RECEIVED:
            pI2C_param->RxData[pI2C_param->RX_I2C_Index++] = I2C_ReceiveData (I2C1);
            break;
        default:
            break;
#endif
i2c_api.rar
4.13 KB, 下载次数: 617
 楼主| armrunc 发表于 2012-2-1 11:39 | 显示全部楼层
认错人了吧,测试没有问题啊。
 楼主| armrunc 发表于 2012-2-1 15:32 | 显示全部楼层
具体实例,使用硬件 I2C 访问 EEPROM.
12_I2C.pdf
615.08 KB, 下载次数: 686
mochou 发表于 2012-2-1 17:37 | 显示全部楼层
帮你顶顶吧,不容易的,
李富贵 发表于 2012-2-1 20:06 | 显示全部楼层
都没说到点子上,STM32的IIC问题是必须最高中断优先级或者DMA模式。
简单做一个例子很容易,难的是在一个复杂系统里面应用IIC(无法分配最高优先级或DMA通道),必死无疑。
 楼主| armrunc 发表于 2012-2-2 22:04 | 显示全部楼层
简单做一个例子很容易,难的是在一个复杂系统里面应用IIC(无法分配最高优先级或DMA通道),必死无疑。 ...
同意,但是你可以看到,我这个中断处理函数非常的短,每个 CASE 的代码量都非常小。即便是最高优先级,对其它中断处理不会有太大的影响。
 楼主| armrunc 发表于 2012-2-2 22:10 | 显示全部楼层
帮你顶顶吧,不容易的,
谢谢。是弄了一段时间。
thcsgpxgy 发表于 2012-9-29 09:36 | 显示全部楼层
我也卡在这儿了,受益了
thcsgpxgy 发表于 2012-10-9 14:46 | 显示全部楼层
程序不完整啊
香水城 发表于 2012-10-9 15:57 | 显示全部楼层
LZ思路很清晰啊
发条裤子:lol
EAMCU 发表于 2012-10-9 18:14 | 显示全部楼层
我司使用stm32时,放弃使用i2c,在实际的系统中,为了可靠性,最高优先级往往轮不到i2c来用
其次,一个有病的模块即使看起来好用了,不代表它真的不再出问题了,对于一个实际的系统来说,如果没有精力和能力做超大量的实验,那么尽量选择本身问题较小的方案
评分
参与人数 1威望 +1 收起 理由
dong_abc + 1
查看全部评分
arthur02 发表于 2012-12-5 11:43 | 显示全部楼层
有没有哪位大侠用 DMA实现的啊?
13249207512 发表于 2012-12-30 20:49 | 显示全部楼层
多谢分享
sinadz 发表于 2012-12-30 21:00 | 显示全部楼层
很有参考价值
can_all 发表于 2014-8-21 17:04 | 显示全部楼层
现如今看来还是挺好的!谢谢lz分享!赞
hqtdzgs 发表于 2014-8-21 21:43 | 显示全部楼层
参与下,
1398117027 发表于 2014-8-30 18:18 | 显示全部楼层
参考下你的例程
liklon 发表于 2014-10-10 14:35 | 显示全部楼层
楼主有STM32iic硬件从发送模式部分吗
