怎么修改代码 自动换行呀 ,求高人指导!!
3557|3
 楼主| z372846985 发表于 2012-2-1 15:15 | 显示全部楼层 |阅读模式
代码:
顶部的两个协议我去掉了! 论坛不让发带连接
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "">
<html xmlns="<head>
<meta http-equiv="Content-Type" content="text/html; charset=<?php bloginfo( 'charset' ); ?>" />
<title>
<?php
global $page, $paged;
if(is_home()){ $options = get_option('xiaotang_options'); echo($options['indextitle']);}else{wp_title( '|', true, 'right' );
bloginfo( 'name' );
if ( $paged >= 2 || $page >= 2 )
  echo ' | ' . sprintf( __( 'Page %s', 'xiaotang' ), max( $paged, $page ) );
</title>
<?php if (is_home()){
$description = ($options['indexdescription']);
$keywords = ($options['indexkeyword']);
} elseif (is_single()){
    if ($post->post_excerpt) {
        $description = $post->post_excerpt;
    } else {
        $description = utf8_CsubStr(strip_tags($post->post_content),0,190);
    $keywords = "";
    $tags = wp_get_post_tags($post->ID);
    foreach ($tags as $tag ) {
        $keywords = $keywords . $tag->name . ", ";
} elseif (is_category()){
$description = strip_tags(category_description());
$categoryname = get_the_category();
$keywords = $categoryname[0]->cat_name;
<meta name="keywords" content="<?php echo $keywords; ?>" />
<meta name="description" content="<?php echo $description; ?>" />
<link rel="stylesheet" href="<?php bloginfo('stylesheet_url'); ?>" type="text/css" media="screen" />
<link rel="alternate" type="application/rss+xml" title="<?php bloginfo('name'); ?> RSS Feed" href="<?php $options = get_option('xiaotang_options'); if ($options['feed_url']) {echo($options['feed_url']);} else  bloginfo('rss2_url'); ?>" />
<link rel="pingback" href="<?php bloginfo('pingback_url'); ?>" />
<?php if ( is_singular() ) wp_enqueue_script( 'comment-reply' ); ?>
<script type="text/javascript" src="<?php bloginfo('template_url'); ?>/js/base.js"></script>
<?php $options = get_option('xiaotang_options'); if ($options['submenu']){?>
<link rel="stylesheet" href="<?php bloginfo('template_url'); ?>/superfish.css" type="text/css" media="screen" />
<script type="text/javascript" src="<?php bloginfo('template_url'); ?>/js/jquery-1.2.6.min.js"></script>
<script type="text/javascript" src="<?php bloginfo('template_url'); ?>/js/hoverIntent.js"></script>
<script type="text/javascript" src="<?php bloginfo('template_url'); ?>/js/superfish.js"></script>
<script type="text/javascript" src="<?php bloginfo('template_url'); ?>/js/jquery.bgiframe.min.js"></script>
<script type="text/javascript">
    $(document).ready(function(){
        $("ul.menu").superfish().find('ul').bgIframe({opacity:false});
</script>
<?}else{?>
<style>#nav ul.sub-menu{display:none;}</style>
<?php }?>
<?php wp_head(); ?>
</head>
<body <?php body_class(); ?>>
<div id="top">
<div id="header">
     <div id="blog_title">
         <h1><a href="<?php echo get_option('home'); ?>/"><?php bloginfo('name'); ?></a></h1>
         <p><?php bloginfo('description'); ?></p>
            <div class="banner"><?php
     // Check if this is a post or page, if it has a thumbnail, and if it's a big one
     $banner_link = $options['banner_link'];
     $banner_link_target = $options['banner_link_target'];
     $banner_link_xfn = $options['banner_link_xfn'];
     if ( is_singular() &&
       has_post_thumbnail( $post->ID ) &&
       ( /* $src, $width, $height */ $image = wp_get_attachment_image_src( get_post_thumbnail_id( $post->ID ), 'post-thumbnail' ) ) &&
       $image[1] >= HEADER_IMAGE_WIDTH ) :
      // Houston, we have a new header image!
      echo get_the_post_thumbnail( $post->ID, 'post-thumbnail' );
     else : ?>
      <a href="<?php echo $banner_link;?>"<?php if($banner_link_target==1) echo ' target="_blank"'; ?><?php if($banner_link_xfn==1) echo ' rel="nofollow"'; ?>><img src="<?php header_image(); ?>" width="<?php echo HEADER_IMAGE_WIDTH; ?>" height="<?php echo HEADER_IMAGE_HEIGHT; ?>" alt="" /></a>
     <?php endif; ?>
            </div>
        </div>
        <div id="nav">
         <?php wp_nav_menu('container=\'\'&menu_id=menu&title_li=&link_before=<span>&link_after=</span>'); ?>
        </div>
    </div>
</div>
<div id="wrap">
来源于:www.16466.com
lifeinjoy 发表于 2012-2-5 17:26 | 显示全部楼层
HTML??发这个干嘛呢
hgjinwei 发表于 2012-2-6 08:45 | 显示全部楼层
踢馆的来了,筒子们快跑啊。
icecut 发表于 2012-2-6 09:19 | 显示全部楼层
php不解释,这段代码看起来是一个通用平台的代码...不是你自己写的.
