STM32F030单片机PB12和PB13设置为PWM输出,在配置的占空比不为0时候,PWM输出波形都是正常的。但是在配置为PWM0时候,正常结果是IO输出低电平,但是实际示波器测试IO脚为低电平但是有很多杂波输出。一下是程序,有高手麻烦帮忙看一下
#define Frequency_Max 1000
#define Frequency_Pulse 0
#define LED5_Num GpioPin12
#define LED6_Num GpioPin13
#define LED5_GPIO GpioPortB
#define LED6_GPIO GpioPortB
#define LED5(a)        Adt_SetCompareValue(AdtTIM6, AdtCompareA, a)
#define LED6(a) Adt_SetCompareValue(AdtTIM6, AdtCompareB, a)
void TIM6_GPIO_Config(void)
        stc_gpio_config_t         stcTIM6Port;
        Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE); //¶Ë¿ÚÍâÉèʱÖÓʹÄÜ
        stcTIM6Port.enDir  = GpioDirOut;
        Gpio_Init(LED5_GPIO, LED5_Num, &stcTIM6Port);
        Gpio_SetAfMode(LED5_GPIO,LED5_Num,LED5_GpioAf);
        Gpio_Init(LED6_GPIO, LED6_Num, &stcTIM6Port);
  Gpio_SetAfMode(LED6_GPIO,LED6_Num,LED6_GpioAf);               //
        while (Ok != Sysctrl_SetPeripheralGate(SysctrlPeripheralAdvTim, TRUE));//ADTÍâÉèʱÖÓʹÄÜ
void TIM6_Mode_Config(void)
        stc_adt_basecnt_cfg_t     stcAdtBaseCntCfg;
        stc_adt_CHxX_port_cfg_t   stcAdtTIM6ACfg;
        stcAdtBaseCntCfg.enCntMode = AdtSawtoothMode;           //Èý½Ç²¨A
        stcAdtBaseCntCfg.enCntDir = AdtCntUp;
        stcAdtBaseCntCfg.enCntClkDiv = AdtClkPClk0;
        Adt_Init(AdtTIM6, &stcAdtBaseCntCfg);                      //ADTÔØ²¨£¬¼ÆÊýģʽ£¬Ê±ÖÓÅäÖà
        Adt_SetPeriod(AdtTIM6, Frequency_Max);                         //ÖÜÆÚ
        Adt_SetCompareValue(AdtTIM6, AdtCompareA, Frequency_Pulse);    //ͨÓñȽϻù×¼Öµ¼Ä´æÆ÷AÉèÖà
        Adt_SetCompareValue(AdtTIM6, AdtCompareB, Frequency_Pulse);    //ͨÓñȽϻù×¼Öµ¼Ä´æÆ÷AÉèÖà
        stcAdtTIM6ACfg.enCap = AdtCHxCompareOutput;
        stcAdtTIM6ACfg.bOutEn = TRUE;
        stcAdtTIM6ACfg.enPerc = AdtCHxPeriodHigh;
        stcAdtTIM6ACfg.enCmpc = AdtCHxCompareLow;
        stcAdtTIM6ACfg.enStaStp = AdtCHxStateSelSS;
        stcAdtTIM6ACfg.enStaOut = AdtCHxPortOutLow;        //¿ªÊ¼¶Ë¿Ú״̬ΪµÍµçƽ
        stcAdtTIM6ACfg.enStpOut = AdtCHxPortOutLow;        //½áÊø¶Ë¿Ú״̬ΪµÍµçƽ
        Adt_CHxXPortConfig(AdtTIM6, AdtCHxA, &stcAdtTIM6ACfg);   //¶Ë¿ÚCHAÅäÖà
        Adt_CHxXPortConfig(AdtTIM6, AdtCHxB, &stcAdtTIM6ACfg);   //¶Ë¿ÚCHAÅäÖà
        Adt_StartCount(AdtTIM6);
