[其他ST产品] 关于树莓派通过蓝牙连接SensorTile.box
625|6
 楼主| 两只袜子 发表于 2020-11-3 11:06 | 显示全部楼层 |阅读模式
打开系统蓝牙
sudo service bluetooth start
进入bluetoothctl
Sudo bluetoothctl
输入以下命令
power on
agent on
default-agent
scan on
pair C0:50:27:32:09:33
连接成功以后
[bluetooth]# pair c0:50:27:32:09:33
Attempting to pair with C0:50:27:32:09:33
[CHG] Device C0:50:27:32:09:33 Connected: yes
[NEW] Primary Service
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001
        00001801-0000-1000-8000-00805f9b34fb
        Generic Attribute Profile
[NEW] Characteristic
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001/char0002
        00002a05-0000-1000-8000-00805f9b34fb
        Service Changed
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0001/char0002/desc0004
        00002902-0000-1000-8000-00805f9b34fb
        Client Characteristic Configuration
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c
        00000000-000e-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char000d
        00000001-000e-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char000d/desc000f
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char0010
        00000002-000e-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service000c/char0010/desc0012
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013
        00000000-0003-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013/char0014
        00000100-0001-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0013/char0014/desc0016
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017
        00000000-0001-11e1-9ab4-0002a5d5c51b
        Vendor specific
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017/char0018
        00020000-0001-11e1-ac36-0002a5d5c51b
        Vendor specific
[NEW] Descriptor
        /org/bluez/hci0/dev_C0_50_27_32_09_33/service0017/char0018/desc001a
而且可以通过info看到
[TILEBOX]# info
Device C0:50:27:32:09:33 (public)
        Alias: TILEBOX
        Paired: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        UUID: Vendor specific           (00000000-0001-11e1-9ab4-0002a5d5c51b)
        UUID: Vendor specific           (00000000-0003-11e1-9ab4-0002a5d5c51b)
        UUID: Vendor specific           (00000000-000e-11e1-9ab4-0002a5d5c51b)
        UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
        UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
很可惜,这个连接不稳定,很快出现
Failed to pair: org.bluez.Error.AuthenticationFailed
[CHG] Device C0:50:27:32:09:33 Connected: no
出现这个问题后,再次连接不成功,即使重启树莓派也无效,但此时只需要重启SensorTile.Box就可以再次连接。
原因暂不明,怀疑是我手上的SensorTile.Box蓝牙不稳定造成。
xixi2017 发表于 2020-11-3 19:23 | 显示全部楼层
传感器模组SensorTile.box
guanjiaer 发表于 2020-12-3 11:49 | 显示全部楼层
现在还有树莓派?
heimaojingzhang 发表于 2020-12-3 11:50 | 显示全部楼层
在什么模式下输入指令啊
keaibukelian 发表于 2020-12-3 11:52 | 显示全部楼层
这两个指令是以什么形式输入呢
labasi 发表于 2020-12-3 11:53 | 显示全部楼层
树莓派手机是不是就是 用来刷机实验用的啊
paotangsan 发表于 2020-12-3 11:55 | 显示全部楼层
连接速度快不快
