[信息] 使用python连接SensorTile.box
449|0
 楼主| laocuo1142 发表于 2020-11-4 10:44 | 显示全部楼层 |阅读模式
在尝试了APP之后,发现SensorTile.box有实时优势,那就是可以通过蓝牙连接,而不是每次取完数据之后从TF卡里面把数据拿出来分析;同时,如果没有实时的蓝牙连接,TF卡里面的数据也足以保证数据记录的完整性,两者相辅相成,互为比较。在这里我尝试用python获取蓝牙数据。首先在笔记本上编写python代码实现tile.box的查找,如下:
import time
from bluetooth import *
alreadyFound = []
def findDevs():
    foundDevs = discover_devices(lookup_names=True)
    for (addr, name) in foundDevs:
        if (addr not in alreadyFound) and (name=='TILEBOX'):
            alreadyFound.append(addr)
if __name__=='__main__':
    while alreadyFound == []:
        findDevs()
        time.sleep(5)
    print(alreadyFound)
执行后,
Python 3.8.3 (tags/v3.8.3:6f8c832, May 13 2020, 22:20:19) [MSC v.1925 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license()" for more information.
================ RESTART: D:\bluetooth\tilebox.py ================
['C0:50:27:32:09:33']
接下来尝试把代码移植到树莓派上,首先需要在树莓派上安装蓝牙组件,sudo apt-get install libbluetooth-dev,安装完成以后,可以通过命令行查看蓝牙设备
pi@raspberrypi:~$ hciconfig
hci0:   Type: Primary  Bus: UART
        BD Address: DC:A6:32:13:8A:2B  ACL MTU: 1021:8  SCO MTU: 64:1
        UP RUNNING
        RX bytes:806 acl:0 sco:0 events:52 errors:0
        TX bytes:2515 acl:0 sco:0 commands:52 errors:0
pi@raspberrypi:~$ hcitool dev
Devices:
        hci0    DC:A6:32:13:8A:2B
本机的蓝牙地址是DC:A6:32:13:8A:2B,激活蓝牙设备
pi@raspberrypi:~$ service bluetooth start
pi@raspberrypi:~$ sudo hciconfig hci0 up
pi@raspberrypi:~$ hcitool scan
很可惜,找不到tile.box,所以代码移植肯定是暂不成功的。后续准备从两方面开展:
1、使用电脑调试信息获取;
2、调通树莓派的蓝牙。
