| #include <c8051f020.h> #include <intrins.h>
 #define uint unsigned int
 #define uchar unsigned char
 sbit SPEAKER=P3^3;
 sbit SLEEP=P3^1;
 sbit WX_RST=P3^2;
 unsigned char warning_flag;
 unsigned char chaomx_flag;
 unsigned char flag;
 unsigned char k;
 unsigned int idata c_timer0;            //计时器
 unsigned char data I2C_RAM[16];        //I2C数据交换RAM
 unsigned char data bat_count;      //电池采样计数
 unsigned char code *pointer;
 unsigned char idata uart0_se;            //uart0口接收开始同步字和结束符个数
 unsigned char idata uart0_num;            //uart0口接收、发送字符个数
 unsigned char idata battery_volt;        //电池电压 battery_volt=60*(battery_ad÷battery_base)
 unsigned char idata battery_base[3];    //电池标称ad值和标称时的电压
 unsigned int idata battery_ad;            //电池当前ad值
 unsigned int idata battery_sampling[4]; //电池采样周期瞬时值
 void main(void)
 //******系统初始化*********************************************
 /*初始化------------------------------*/
 P1MDIN=0xFF;
 EMI0CF=0x03;
 XBR0=0x04; //00000100B       /* UART0*/
 //    XBR1=0x04; //00000100B       /* INT0 */
 XBR2=0x42; //01000010B       /* 弱上拉允许,允许交叉开关,UART1不连到端口 */
 //UART0初始化
 TL1=0xfd;
 TH1=0xfa;            //定时器T1装载值  FDH(9600), FAH(4800), F4H(2400), E8(1200)
 SCON0=0x50;          //设串口UART0为模式1(用于无线通信或PC通信)  (用T1)
 //定时器设定
 CKCON=0x00;          //T0,T1,T2,T4使用SYSCLK的12分频
 T2CON=0x04;           //T1为UART0串口波特率发生器,启动T2
 TMOD=0x21;            //T0为定时方式1,T1为8位自动装载为UART0串口波特率发生器
 TR1=1;                //启动T1
 //DAC0设置
 P0MDOUT=0x01; //00000001B     /*P0配置*/
 P1MDOUT=0xff;                 /*P1*/
 P2MDOUT=0xff;                 /*P2*/
 P3MDOUT = 0xff; //11111111B  P3口配置 /*各个端口输入时配置为漏极开路,输出时配置为推挽方式*/
 P74OUT=0x00;
 P4=P4&0xd3;                   /*ALE=0,A16=0(P4.3),LCDE=0(P4.2)*/
 WDTCN=0xde;                   /*暂时禁止看门狗定时器*/
 WDTCN=0xad;
 SCON0=SCON0&0xfc;    //清TI0,RI0
 //外部中断设置
 IE0=0;  /* 清中断标志 */
 ES0=1;            //开放串口UART0中断
 EA=1;         //开总中断
 AMX0SL=0x07;
 //初始化
 P5=P5&0xfd;        //开机点亮工作灯
 while (1);
 void uart0_rt(void) interrupt 4
 k=0;
 if (RI0==1)
 RI0=0;
 k=SBUF0;
