[MCU]
下载程序load错误
384|4
huanghuac|  楼主 | 2020-11-5 23:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
屏幕下方出现Trouble Writing Memory Block at 0xac0 on Page 0 of Length 0xac0: Error 0x00000002/-1153 Error during: Memory,  The memory at 0x01BC0010 continually indicated it was 'not ready' All memory operations currently in progress were aborted in order to regain control of the processor. This is considered a catastrophic event, but the debugger should  still be able to access memory and CPU registers. System state has been altered.  It is strongly advised that the processor should be reset before resuming execution,   Sequence ID: 1 Error Code: -1153 Error Class: 0x00000002
jiahy| | 2020-11-5 23:58 | 只看该作者
好像是说设备没准备好
lizye| | 2020-11-16 19:26 | 只看该作者
那咋办啊
jiahy| | 2020-11-16 19:32 | 只看该作者
这种问题没有统一的答案,你自己多测测吧
lizye| | 2020-11-16 19:36 | 只看该作者
好吧,明天再请教大家
