怎么用LCD1602显示特殊字符
2621|0
 楼主| caowei 发表于 2012-2-2 22:59 | 显示全部楼层 |阅读模式
显示特殊字符时候(天线形式)其他区域也回出现乱点,不知道怎么解决???
源程序如下(主函数):
#include <hidef.h>
#include "derivative.h"
#include "LLD_LCD.h"
#include "LLD_KEY.h"
void PerphInit()
  SOPT1 = 0x00;       //关闭看门狗
  MCGC1 = 0xB8;
  MCGC1_IRCLKEN = 1;  //开启参考时钟,TRIM微调量没有设置
  MCGC2 = 0x36;
  MCGC3 = 0x00;       //PLLS=0
  while(!(MCGSC&0x02));
   void tianxian(void)//显示天线形
        LcdCommand(0x36);
       LcdCommand(0x80);//垂直地址范围
     LcdCommand(0x80);//水平地址范围
     LcdDataWrite(0x80);
        LcdCommand(0x81);//垂直地址范围
     LcdDataWrite(0x2a);
        LcdCommand(0x82);//垂直地址范围
        LcdDataWrite(0x1c);
        LcdCommand(0x83);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x84);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x85);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x86);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x87);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x88);//垂直地址范围
        LcdDataWrite(0x08);
        LcdCommand(0x70);//水平地址范围
        LcdDataWrite(0x07);*/
//======主函数=====
void main(void)
        PerphInit();   //外围初始化
       LCD_Init();     //液晶...
     EnableInterrupts;
       CLR_Screen();
      while(1)
      {    uchar key = 0x00;  //按键标志符赋初值
        do {
                        key = Get_Key();    //读取按键
            }while(!key);
              switch(key)
               case UP:
                 CLR_Screen();
                 DisplayChar(0,0,"发送中...");
                 break;
               case DOWN:
                 CLR_Screen();
                 DisplayChar(0,0,"接收中...");
                    break;
               case BACK:
                 tianxian();     //天线字形
             Delay(1000);
                  break;
                default:
                         break;
              } //end switch
       }//end while
