[MCU] MSP430F5529 ADC12_A初始化参考
579|5
 楼主| 两只袜子 发表于 2020-11-6 11:24 | 显示全部楼层 |阅读模式
typedef struct ADC_MemMap
  union
    uint16_t CTL0;
    struct
      uint16_t SC             :1;  /* ADC12 Start Conversion */
      uint16_t ENC            :1;  /* ADC12 Enable Conversion */
      uint16_t TOVIE          :1;  /* ADC12 Timer Overflow interrupt enable */
      uint16_t OVIE           :1;  /* ADC12 Overflow interrupt enable */
      uint16_t ON             :1;  /* ADC12 On/enable */
      uint16_t ADCREFON       :1;  /* ADC12 Reference on */
      uint16_t REF2_5V        :1;  /* ADC12 Ref 0:1.5V / 1:2.5V */
      uint16_t MSC            :1;  /* ADC12 Multiple SampleConversion */
      uint16_t SHT0           :4;  /* ADC12 Sample Hold 0 Select  */
      uint16_t SHT1           :4;  /* ADC12 Sample Hold 1 Select  */
  union
    uint16_t CTL1;
    struct
      uint16_t ADBUSY         :1;    /* ADC12 Busy */
      uint16_t CONSEQ         :2;    /* ADC12 Conversion Sequence Select  */
      uint16_t SSEL           :2;    /* ADC12 Clock Source Select  */
      uint16_t DIV            :3;    /* ADC12 Clock Divider Select  */
      uint16_t ISSH           :1;    /* ADC12 Invert Sample Hold Signal */
      uint16_t SHP            :1;    /* ADC12 Sample/Hold Pulse Mode */
      uint16_t SHS            :2;    /* ADC12 Sample/Hold Source  */
      uint16_t CSTARTADD      :4;    /* ADC12 Conversion Start Address  */
  union
    uint16_t CTL2;
    struct
      uint16_t REFBURST       :1;    /* ADC12+ Reference Burst */
      uint16_t ADCREFOUT      :1;    /* ADC12+ Reference Out */
      uint16_t SR             :1;    /* ADC12+ Sampling Rate */
      uint16_t DF             :1;    /* ADC12+ Data Format */
      uint16_t RES            :2;    /* ADC12+ Resolution  */
      uint16_t TCOFF          :1;    /* ADC12+ Temperature Sensor Off */
      uint16_t PDIV           :1;    /* ADC12+ predivider 0:/1   1:/4 */
  uint16_t RESERVED_1[2];
  uint16_t IFG;
  uint16_t IE;
  uint16_t IV;
  struct
      uint8_t INCH            :4;     /* ADC12 Input Channel Select*/
      uint8_t REF             :3;     /* ADC12 Select Reference  */
      uint8_t EOS             :1;     /* ADC12 End of Sequence */
  }MCTL[16];
  uint16_t MEM[16];
}volatile * ADC_MemMapPtr;
#define ADC12_SSEL_ADC12OSC       0
#define ADC12_SSEL_ACLK           1
#define ADC12_SSEL_MCLK           2
#define ADC12_SSEL_SMCLK          3
#define ADC12_SREF_0            0
#define ADC12_SREF_1            1
#define ADC12_SREF_2            2
#define ADC12_SREF_3            3
#define ADC12_SREF_4            4
#define ADC12_SREF_5            5
#define ADC12_SREF_6            6
#define ADC12_SREF_7            7
#define ADC_BASE_PTR                     ((ADC_MemMapPtr)__MSP430_BASEADDRESS_ADC12_PLUS__)
paotangsan 发表于 2020-12-2 15:59 | 显示全部楼层
这是初始化成那种采样模式了啊
renzheshengui 发表于 2020-12-2 16:00 | 显示全部楼层
对io口的初始化呢?
wakayi 发表于 2020-12-2 16:02 | 显示全部楼层
都是头文件的内容吧
wowu 发表于 2020-12-2 16:04 | 显示全部楼层
很多定义都是第一次看见
xiaoqizi 发表于 2020-12-2 16:05 | 显示全部楼层
需要引用哪些文件呢
