[PIC®/AVR®/dsPIC®产品] 【CuriosityNano测评报告】+片内DAC外设测评——生成正弦波
2748|21
 楼主| mxkw0514 发表于 2020-11-9 11:45 | 显示全部楼层 |阅读模式
本次测试工作主要包含3个方面:
1、开箱展示
2、项目测试
3、心得
1、开箱展示:
PIC18F57Q43 Curiosity Nano评估工具包
做得很精致,贴片电容、电阻使用的都是0402封装,使得开发板的元器件的布局更为紧凑、板子的尺寸能够做得更小。开箱展示如图1.1所示:
        图1.1
从图上可以看出这款工具包是在马来西亚产的。PCB板上的排针孔排列得错落有致,其目的是为了不用焊接就能固定排针,只需一台电脑和一根下载线就能开始测试。当插上USB先后,发现电脑突然出了一点变化,变化如图1.2所示:
        图1.2
貌似出现了类似与“U盘”一样的东西,里面的文件列写了器件的编号以供查验。PIC18F57Q43的EEPROM被当作“U”盘来使用了,内存不大,才1.1M左右,不过存储一些记事本文件还是可以的。
2、项目测试:
根据芯片数据手册:
                                                          图2.1
可知,芯片的DAC输出引脚在RA2和RA3两个引脚,同时这两个引脚也是ADC复用引脚,根据数据手册,对DAC相关寄存器进行配置:
                                                          图2.2
void DAC1_Initialize(void){
    DAC1CON = 0xA0;// 使能OE DACOUT1,禁用DACOUT2; 使能DAC1EN,NSS VSS; PSS VDD;
    DAC1DATL = 0x33;// DAC1R 51;
void DAC1_SetOutput(uint8_t inputData)
    DAC1DATL  = inputData;
uint8_t DAC1_GetOutput(void)
    return DAC1DATL;
项目利用PIC18F57Q43中的DAC实现正弦波输出,主要思路是将一个正弦波分成254个幅值输出,输出引脚为RA2。项目代码如下:
#include "mcc_generated_files/mcc.h"
    return DAC1DATL;
void main(void)
    DAC1_Initialize();
    unsigned char  sin_tab[]={
   125,128,131,134,138,141,144,147,150,153,156,159,162,165,168,171,
   174,177,180,182,185,188,191,193,196,198,201,203,206,208,211,213,
   215,217,219,221,223,225,227,229,231,232,234,235,237,238,239,241,
   242,243,244,245,246,246,247,248,248,249,249,250,250,250,250,250,
   250,250,250,249,249,248,248,247,246,246,245,244,243,242,241,239,
   238,237,235,234,232,231,229,227,225,223,221,219,217,215,213,211,
   208,206,203,201,198,196,193,191,188,185,182,180,177,174,171,168,
   165,162,159,156,153,150,147,144,141,138,134,131,128,125,122,119,
   116,112,109,106,103,100, 97, 94, 91, 88, 85, 82, 79, 76, 73, 70,
   68,  65, 62, 59, 57, 54, 52, 49, 47, 44, 42, 39, 37, 35, 33, 31,
   29,  27, 25, 27, 29, 27, 25, 23, 21, 19, 18, 16, 15, 13, 12, 11,
   9,    8,  7,  6,  5,  4,  4,  3,  2,  2,  1,  1,  0,  0,  0,  0,
   0,    0,  0,  0,  1,  1,  2,  2,  3,  4,  4,  5,  6,  7,  8,  9,
   11,  12, 13, 15, 16, 18, 19, 21, 23, 25, 27, 29, 31, 33, 35, 37,
   39,  42, 44, 47, 49, 52, 54, 57, 59, 62, 65, 68, 70, 73, 76, 79,
   82,  85, 88, 97, 94, 97,100,103, 106,109,112,116,119,122};
   unsigned int ms;
   while (1)
       for(ms=0;ms<254;ms++)
           DAC1_SetOutput( sin_tab[ms]);
测试结果如下所示(详细结果见附件):
        图2-3
3、心得
经过一点时间的摸索,终于实现了利用PIC18F57Q43中的DAC输出正弦波,总体来看效果还不错,可惜的是这次没有实现用MCC的功能将正弦波输出,可能是我没有掌握方法吧,感觉直接利用数据手册的寄存器比操作MCC要容易。这款单片机内部集成了DAC,就不需要外加DAC了,虽然只是一个8位的DAC,但可以适用很多场合了,这可以给一些项目的开发省下一些成本,但是话又说回来,PIC18F57Q43这款单片机的价格不是很便宜,如果它的价格单片能和Atmeg328p差不多,相信用它做项目开发的人会变多吧。
pzsh 发表于 2020-11-25 10:52 | 显示全部楼层
DAC 部分呢,期待
 楼主| mxkw0514 发表于 2020-11-28 20:08 | 显示全部楼层
DAC 部分呢,期待
可以点评了
输出的正弦波看上去很平滑,非常不错  发表于 2021-2-2 13:20
gejigeji521 发表于 2020-11-9 11:59 | 显示全部楼层
这是准备输出正玄波吗
 楼主| mxkw0514 发表于 2020-11-9 12:04 | 显示全部楼层
这是准备输出正玄波吗
不会跟你的项目冲突了吧
玛尼玛尼哄 发表于 2020-11-9 19:34 | 显示全部楼层
牛啊,出波形了吗
BettyBerry 发表于 2020-11-28 22:39 | 显示全部楼层
谢谢楼主 借用一下你的码
索尼法 发表于 2020-11-28 22:49 | 显示全部楼层
不懂就问 DAC是什么模块 刚入门
函数不想导 发表于 2020-11-29 23:14 | 显示全部楼层
还挺不错的板子
 楼主| mxkw0514 发表于 2020-12-5 19:18 | 显示全部楼层
不懂就问 DAC是什么模块 刚入门
DAC我也是刚开始学
heisexingqisi 发表于 2020-12-5 23:49 | 显示全部楼层
这板子不错。
aspoke 发表于 2021-3-7 21:06 | 显示全部楼层
自带几个ADC呢?
232321122 发表于 2021-3-7 21:06 | 显示全部楼层
单片机内部DAC精度多少呢
ghuca 发表于 2021-3-7 21:06 | 显示全部楼层
soodesyt 发表于 2021-3-7 21:07 | 显示全部楼层
PIC18F57Q43 看着性能不错。
mnynt121 发表于 2021-3-7 21:07 | 显示全部楼层
展示的效果还是不错的。
plsbackup 发表于 2021-3-7 21:07 | 显示全部楼层
PIC18F57Q43 Curiosity Nano怎么样呢
kmzuaz 发表于 2021-3-7 21:07 | 显示全部楼层
期待楼主更多分享了。
iyoum 发表于 2021-3-7 21:07 | 显示全部楼层
查表输出吗
wengh2016 发表于 2021-3-7 21:07 | 显示全部楼层
波形很棒。
