[MCU] 我的捕获程序只能进一次中断怎么办求大神
1130|0
 楼主| laocuo1142 发表于 2020-11-13 11:11 | 显示全部楼层 |阅读模式
se, AC, TI, timer, hz
void setclock(void)
    WDTCTL = WDTPW + WDTHOLD;                // watchdog timer setup
        if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)
          while(1);                                    // If cal constants erased, trap CPU!!
        BCSCTL1 = CALBC1_1MHZ;                         // Set range
        DCOCTL = CALDCO_1MHZ;                         // Set DCO step + modulation
        IFG1 &= ~OFIFG;
void settimer(){
        TACTL=TACLR;
        TACTL=TASSEL_2+MC_2;
        TACCTL1=CM_3+CCIS_0+CAP+CCIE;
        TACCTL1&=~CCIFG;
        _EINT();
void setgpio(){
  P1DIR=0X01;
  P1OUT=0X01;
  P1SEL=BIT2+BIT1;
void main(void)
    setclock();
    setgpio();
    settimer();
    while(1);
#pragma vector=TIMER0_A1_VECTOR
__interrupt void Timer_A (void)
  if(TACCTL1&CCIFG){
    TACCTL1&=CCIFG;
    //CC=CCR1-C;
    //C=CCR1;
    P1OUT^=BIT0;
