[技术问答] 谁能帮我看看n76e003可调电源的程序
1405|4
 楼主| 171650333 发表于 2020-11-16 13:57 | 显示全部楼层 |阅读模式
开机后oled上ADC电压值有变化,旋转编码器后,oled就显示一个值没有变化
#include <stdio.h>
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_Define.h"
#include "oled.h"
#include "bmp.h"
UINT8 temp=0xD7;
UINT8 temp1=0x02;
void ADC_ISR (void) interrupt 11
        if(ADCF)
                clr_ADCF;
                set_ADCS;
//printf ("\n Value = 0x%bx",ADCRH);
void show()
         uint16_t BandGap_H, BandGap_L,BandGap_v;
         uint16_t  voltage = 0;
          char aa[10];
          float  v;
                BandGap_H = ADCRH;
                BandGap_L = ADCRL;
                BandGap_v = BandGap_H << 4 | BandGap_L;
                v=(float)BandGap_v*(3.3/4096);
                v*=10;
          sprintf(aa,"%5.2f",v);
                OLED_ShowString(0,0,aa);
void main (void)
//        unsigned char t;
//        uint16_t BandGap_H, BandGap_L,BandGap_v,temp;
//        uint16_t  voltage = 0;
//        char aa[10];
//        float  v;
        Set_All_GPIO_Quasi_Mode;                                        // Define in Function_define.h
        P17_Input_Mode;
        P30_Input_Mode;
        set_EPI;
        clr_PIPS1;
        set_PIPS0;
  Enable_BIT7_RasingEdge_Trig;
        Enable_ADC_AIN2;        // Enable AIN0 P1.7 as ADC input
  set_EADC;        // Enable ADC interrupt (if use interrupt)
        set_EPWM;//??
        PWM_INT_PWM4;
  PWM_FALLING_INT;
        PWM4_P01_OUTPUT_ENABLE;
  clr_PWMTYP;//??????
  clr_PWMMOD0;//?????????
  clr_PWMMOD1;
  PWM_CLOCK_DIV_8;//8????
  PWMPH = 0x07;        //Setting PWM value
        PWMPL = 0xCF;
        set_SFRPAGE;//PWM4 and PWM5 duty seting is in SFP page 1
  PWM4H = 0x02;//500(Dec)
  PWM4L = 0xD7;
        clr_SFRPAGE;
        set_LOAD;        // PWM run
        set_PWMRUN;
        set_EA;
        set_ADCS;
        InitialUART0_Timer3(115200);
        set_CLOEN;
        OLED_Init();                        //³õʼ»¯OLED
        //        t=' ';
  while(1)
        show();
        Timer0_Delay1ms(300);
void PWMISR() interrupt 13
        if(PWMF)//????????
                  clr_LOAD;//????????
                  clr_PWMF;//??PWM?????
                   PWM4H=temp1;
                   PWM4L=temp;
                clr_SFRPAGE;
                set_LOAD;//????,????
                clr_PWMF;
void PinInterrupt (void) interrupt 7
                if(PIF==0x80&&P17)
                        Timer0_Delay1ms(1);
                        if(P17)
                                if(P30)
                  temp+=30;
                                        if(temp<30)
                                                         if(temp1==7){temp=0xc0;}else{temp1+=1;}}
                        //Timer0_Delay1ms(500);
                                else{
           temp-=30;
                                        if(temp<30){
                                        if(temp1==0){temp=0x30;}else{temp1-=1;temp=0xff;}}
                                PIF=0;
        PWMF=1;
jasontu 发表于 2020-11-17 08:13 | 显示全部楼层
因为你的代码,adc只转一次而已,要放在WHILE里面,触发ADC转换才是。
wahahaheihei 发表于 2020-11-17 13:27 | 显示全部楼层
没有更新?
 楼主| 171650333 发表于 2020-11-19 11:28 | 显示全部楼层
不转编码器就有更新,删除编码器里的延时就好了不知道为什么
 楼主| 171650333 发表于 2020-11-19 11:29 | 显示全部楼层
不转编码器又有更新
