[STM32F0] STM32F031我只想要个捕获而已,咋就这么难
4828|50
 楼主| 〽️〽️〽️ 发表于 2020-11-25 17:43 | 显示全部楼层 |阅读模式
背景:
STM32F031F6P6, TSSOP20,采用的是内置晶振8MHz 倍频到48MHz
PA0口捕获脉冲信号对应通道是 TIM2-CH1,
搞了20天了,实在搞不出了,来问问看
问题就是  if(TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET) 一直进不去
按31楼 指导方式:
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN; 或
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
加了  GPIO_PinAFConfig(GPIOA,GPIO_Pin_0,GPIO_AF_2);
但还是不能进入 if(TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
void TIM2_IRQHandler(void)
    if ( TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET )
       //可以正常1ms进入
       TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
         //解码的关键地方
         //可从来没有进入过!!!!!!  备注:这里PA0输入信号高低电平是正常的
        TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
void TIM2_Cap_Init(void)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    TIM_ICInitTypeDef  TIM_ICInitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    TIM_DeInit(TIM2);
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_0;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    TIM_TimeBaseStructure.TIM_Period =48-1;
    TIM_TimeBaseStructure.TIM_Prescaler =1000-1;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
    TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter = 0x00;
    TIM_ICInit(TIM2, &TIM_ICInitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_ITConfig(TIM2,TIM_IT_Update|TIM_IT_CC1,ENABLE);
    TIM_Cmd(TIM2,ENABLE );
int  main(void)
      SetSysClock();
      delay_init(48);
      //略...
      TIM2_Cap_Init();
      while(1)
              while ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)!= RESET);  //测试用 无意义,证明PA0有电平变化,不会一直高电平
              while ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)!= SET);      //测试用 无意义,证明PA0有电平变化,不会一直低电平
              //其他 无关联函数 测试时 也是注销掉了,防止其他导致的错误 略...
里面有晴雨 发表于 2020-11-25 17:54 | 显示全部楼层
我看了一下,你的代码有问题。
9dome猫 发表于 2020-11-25 18:25 | 显示全部楼层
当局者迷
玛尼玛尼哄 发表于 2020-11-25 21:45 | 显示全部楼层
哈哈,会者不难。图形化配置看看。
airwill 发表于 2020-11-25 21:46 | 显示全部楼层
简单的要求,  要这么长大段代码实现.
没办法,  功能强的芯片, 初始化代码也多
9dome猫 发表于 2020-11-25 23:27 | 显示全部楼层
lidi911 发表于 2020-11-26 07:39 来自手机 | 显示全部楼层
代码有问题
 楼主| 〽️〽️〽️ 发表于 2020-11-26 10:06 | 显示全部楼层
我看了一下,你的代码有问题。
大哥,啥问题,教教小弟
 楼主| 〽️〽️〽️ 发表于 2020-11-26 10:07 | 显示全部楼层
大哥,啥问题,教教小弟
香水城 发表于 2020-11-26 10:57 | 显示全部楼层
关键是把原理搞清楚,再结合下库代码里的例程消化下 就可以 搞定了。
海滨消消 发表于 2020-11-26 14:20 | 显示全部楼层
估计是你原理没搞清楚吧
wangjiahao88 发表于 2020-11-26 15:19 | 显示全部楼层
学习学习!
定时器 捕获吧!
 楼主| 〽️〽️〽️ 发表于 2020-11-26 15:37 | 显示全部楼层
又是一天过去了,还是不行,明天继续了
谭翬 发表于 2020-11-26 16:36 | 显示全部楼层
unsigned char H_state;
void TIM2_IRQHandler(void)//定义中断产生时间100us
if ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)== 0) {
     if(h_state==1){
        //下降沿
       _nop_();
     H_state=0;
else{
    if(H_state==0){
            //上升沿
             _nop_();
     H_state=1;
谭翬 发表于 2020-11-26 17:00 | 显示全部楼层
//脉冲宽度最小为200us,如果还小可以改变定时中断时间unsigned char H_state,up,down;
     if(h_state==1){
        //下降沿
       down=1;
     H_state=0;
else{
    if(H_state==0){
            //上升沿
             up=1;
     H_state=1;
int  main(void)
      SetSysClock();
      delay_init(48);
      //略...
      TIM2_Cap_Init();
      while(1)
             if(up==1){up=0;}          //测试用,证明PA0是上升沿
             if(down==1){down=0;}  //测试用,证明PA0是下降沿
              //略...
 楼主| 〽️〽️〽️ 发表于 2020-11-27 09:35 | 显示全部楼层
void TIM2_IRQHandle ...
谢谢,您的方案我看明白了
但是因为实际应用是解码Manchester码,还是捕获的方式好
不用捕获,用扫描方式已经好了,现在是改成捕获
谭翬 发表于 2020-11-27 10:47 | 显示全部楼层
定时器解码:
1、找到时序的开始电平后,开始高低电平的时间检测;
2、高电平时间、低电平时间,判断是否为0、1;不满足条件,回到第1步;
3、检测下一位,位数+1;收到指定位数后,发消息给主程序;
4、主程序 获得消息,对字节读取并判断和控制。
kingsleych 发表于 2020-11-28 10:48 来自手机 | 显示全部楼层
没用过f103的,倒是f030  042 072都弄过,cubemx点了点就好了
 楼主| 〽️〽️〽️ 发表于 2020-11-28 14:55 | 显示全部楼层
还是没进入
继续干!
 楼主| 〽️〽️〽️ 发表于 2020-11-28 14:56 | 显示全部楼层
不是103, 是031和f030基本一样
