调试了几天都没有调试成功,芯唐自带的例程也是有问题的。还道园地发帖求助也没有人回答。今天晚上调试通过了。是 uint32_t SpiFlash_ReadStatusReg1(void)函数有问题。-
- /* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved. */
- #include "includes.h" //°üº¬ËùÐèµÄÍ·Îļþ
- uint32_t i2cdata = 0,u32TxData,u32RxData;
- uint8_t count;
- uint8_t flag;
- uint8_t u32write, u32read, u32PageNumber;
- uint8_t DataBuffer0[256];
- #define TEST_NUMBER 1 /* ¶¨Òå²âÊÔÒ³Êý */
- //#define Enable_SPI_CS DrvGPIO_ClrBit(E_PORT3,5)
- //#define DISABLE_SPI_CS DrvGPIO_SetBit(E_PORT3,5)
- void SpiFlash_ChipErase(void)
- uint32_t au32SourceData;
- /* ÉèÖÃSPI³¤¶ÈΪ8¸öλԪ */
- DrvSPI_SetBitLength(8);
- /* Ƭѡ½ÅÉèΪÆô¶¯×´Ì¬ */
- DrvSPI_SetSS();
- /* ´«ËÍ0x06ÃüÁî, Write enable */
- au32SourceData = 0x06;
- DrvSPI_SingleWrite(&au32SourceData);
- /* µÈ´ý´«ËͽáÊø */
- while (DrvSPI_IsBusy());
- /* Ƭѡ½ÅÉèΪ·ÇÆô¶¯×´Ì¬ */
- DrvSPI_ClrSS();
- DrvSPI_SetSS();
- /* ´«ËÍ0xC7ÃüÁî, Chip Erase */
- au32SourceData = 0xc7;
- /* µÈ´ý´«ËͽáÊø */
- DrvSPI_ClrSS();
- /*uint32_t SpiFlash_ReadStatusReg1(void)
- uint32_t au32DestinationData;
- DrvSPI_SetBitLength(16);
- DrvSPI_SetSS();
- au32SourceData = 0x05;
- DrvSPI_ClrSS();
- DrvSPI_DumpRxRegister(&au32DestinationData, 1);
- return (au32DestinationData & 0xFF);
- uint32_t SpiFlash_ReadStatusReg1(void)
- DrvSPI_SetSS();
- /* ´«ËÍ0x05ÃüÁî, Read status register 1 */
- /* µÈ´ý´«ËͽáÊø */
- /* ¿ªÊ¼½ÓÊÕ×ÊÁÏ */
- au32SourceData = 0x0;
- /* µÈ´ý´«ËͽáÊø */
- DrvSPI_ClrSS();
- /* ´ÓRx¼Ä´æÆ÷ÄÚ¶ÁÈ¡×ÊÁÏ */
- void SpiFlash_WaitReady(void)
- uint32_t ReturnValue;
- do
- ReturnValue = SpiFlash_ReadStatusReg1();
- ReturnValue = ReturnValue & 1;
- while (ReturnValue != 0); // check the BUSY bit
- void SpiFlash_PageProgram(uint8_t *DataBuffer, uint32_t StartAddress, uint32_t ByteCount)
- uint32_t Counter;
- DrvSPI_SetSS();
- /* µÈ´ý´«ËͽáÊø */
- DrvSPI_ClrSS();
- DrvSPI_SetSS();
- /* ´«ËÍ0x02ÃüÁî, Page program */
- au32SourceData = 0x02;
- // wait
- // configure transaction length as 24 bits
- DrvSPI_SetBitLength(24);
- // send 24-bit start address
- au32SourceData = StartAddress;
- /* µÈ´ý´«ËͽáÊø */
- for (Counter = 0; Counter < ByteCount; Counter++)
- /* ´«ËÍ×ÊÁÏ */
- au32SourceData = DataBuffer[Counter];
- /* µÈ´ý´«ËͽáÊø */
- DrvSPI_ClrSS();
- void SpiFlash_ReadData(uint8_t *DataBuffer0, uint32_t StartAddress, uint32_t ByteCount)
- uint32_t Counter;
- DrvSPI_SetSS();
- /* ´«ËÍ0x03ÃüÁî, Read data */
- au32SourceData = 0x03;
- /* µÈ´ý´«ËͽáÊø */
- /* ÉèÖÃSPI³¤¶ÈΪ24¸öλԪ */
- /* ´«ËÍ24λԪλַ×ÊÁÏ */
- /* µÈ´ý´«ËͽáÊø */
- /* ¶ÁÈ¡×ÊÁÏ */
- /* µÈ´ý´«ËͽáÊø */
- DataBuffer0[Counter] = (uint8_t) au32DestinationData;
- DrvSPI_ClrSS();
- ** Function name: main
- ** Descriptions:
- ** input parameters: ÎÞ
- ** output parameters: ÎÞ
- ** Returned value: ÎÞ
- int main (void)
- uint8_t WriteBuffer[256] = {0};
- uint16_t i, id = 1;
- uint8_t ReadBuffer[256] = {0};
- //ReadBuffer[0]=0xfe;
- Set_System();
- ReadBuffer[0]=8; //µ÷ÓÃϵͳ³õʼ»¯º¯Êý
- u32write=0X90;
- /* ÉèÖÃSPI I/O */
- DrvGPIO_InitFunction(FUNC_SPI);
- /* ÉèÖÃSPIΪÖ÷ģʽ, 32-bit ´«Êä */
- DrvSPI_Open(eDRVSPI_MASTER, eDRVSPI_TYPE1, 32);
- /* ÅäÖô«ÊäʱµÄ±ÈÌØÓÅÏÈ´ÎÐòΪMSBÓÅÏÈ */
- DrvSPI_SetEndian(eDRVSPI_MSB_FIRST);
- /* ¹Ø±Õ×Ô¶¯Æ¬Ñ¡¹¦ÄÜ */
- DrvSPI_DisableAutoSS();
- /* É趨ƬѡÐÅºÅÆô¶¯µçƽΪƬѡÐÅºÅµÍµçÆ½»òÕßϽµÑØÆô¶¯ */
- DrvSPI_SetSlaveSelectActiveLevel(eDRVSPI_ACTIVE_LOW_FALLING);
- /* ÉèÖÃSPIʱÖÓËÙ¶ÈΪ 12MHz */
- DrvSPI_SetClockFreq(1000000, 0);
- // DISABLE_SPI_CS;
- /* ²Á³ýSPI flash */
- SpiFlash_ChipErase();
- /* µÈ´ý²Á³ý½áÊø */
- SpiFlash_WaitReady();
- SpiFlash_ReadData(ReadBuffer,0,256);
- DrvGPIO_ClrBit(E_PORT3, 1); //LED0-ON Erase OK
- // delay_ms(1000);
- /* SpiFlash_PageProgram(&u32write,0, 1);
- DrvGPIO_ClrBit(E_PORT3, 6); //LED1-ON //Program done
- delay_ms(1000);
- SpiFlash_ReadData(&u32read,0, 1);
- if (u32write !=u32read)
- DrvGPIO_ClrBit(E_PORT2, 6); //LED3-ON Verify Error
- //delay_ms(1000);
- //while (1);
- DrvGPIO_ClrBit(E_PORT5, 2); //LED2-ON Verify OK
- delay_ms(1000);
- DrvSPI_Close();
- //delay_ms(200);*/
- for(i=0;i<256;i++) //³õʼ»¯Êý×é
- WriteBuffer = i;
- SpiFlash_WaitReady(); //W25Q16BVæ״̬¼ì²é
- // SPI_SectorErase(0x0000); //ÉÈÇø²Á³ý
- SpiFlash_PageProgram(WriteBuffer,0,256); //W25Q16BV°´Ò³±à³Ìº¯Êý
- //delay_ms(1000); //W25Q16BVæ״̬¼ì²é
- SpiFlash_ReadData(ReadBuffer,0,256); //W25Q16BV¶ÁÊý¾Ýº¯Êý
- //SpiFlash_WaitReady();
- //delay_ms(1000);
- for(i=0;i<256;i++) //½«¶Á³öÀ´µÄÊý¾ÝÓëд½øÈ¥µÄÊý¾Ý½øÐбȽÏ
- if(WriteBuffer != ReadBuffer)
- DrvGPIO_ClrBit(E_PORT5, 2); //LED2-ON Verify not OK
- else
- while(1);
