[MCU] 430的定时器中的连续计数问题
539|0
 楼主| 两只袜子 发表于 2020-12-2 10:11 | 显示全部楼层 |阅读模式
  • //  MSP430G2xx3 Demo - Timer_A, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
  • //  Description: Toggle P1.0 using software and TA_0 ISR. Toggles every
  • //  50000 SMCLK cycles. SMCLK provides clock source for TACLK.
  • //  During the TA_0 ISR, P1.0 is toggled and 50000 clock cycles are added to
  • //  CCR0. TA_0 ISR is triggered every 50000 cycles. CPU is normally off and
  • //  used only during TA_ISR.
  • //  ACLK = n/a, MCLK = SMCLK = TACLK = default DCO
  • //           MSP430G2xx3
  • //     /|\|            XIN|-
  • //      --|RST        XOUT|-
  • //        |           P1.0|-->LED
  • //  D. Dang
  • //  Texas Instruments Inc.
  • //  December 2010
  • //   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
  • #include <msp430g2553.h>
  • void main(void)
  •   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  •   P1DIR |= 0x01;                            // P1.0 output
  •   CCTL0 = CCIE;                             // CCR0 interrupt enabled
  •   CCR0 = 50000;
  •   TACTL = TASSEL_2 + MC_2;                  // SMCLK, contmode
  •   _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
  • // Timer A0 interrupt service routine
  • #pragma vector=TIMER0_A0_VECTOR
  • __interrupt void Timer_A (void)
  •   P1OUT ^= 0x01;                            // Toggle P1.0
  •   CCR0 += 50000;                            // Add Offset to CCR0
复制代码
使用430G2553开发板,定时器采用连续计数模式,计数50000个时钟周期,产生中断,中断服务程序中中翻转P1.0电平,
测了一下p1.0输出波形,怎么是这样的?和预期不太一样,感觉应该是一个脉冲宽度为50000个时钟周期的方波,求解答。
而且SMCLK的频率为多少呢,手册没找到
file:///E:\FilesByQQ\MobileFile\1492588565486.jpg
此帖出自微控制器 MCU论坛
[url=][/url]
