C语言怎样快速跟踪到指针函数调用到实际的函数
635|0
 楼主| wenxusun 发表于 2020-12-2 21:08 | 显示全部楼层 |阅读模式
rt_size_t rt_i2c_transfer(struct rt_i2c_bus_device *bus,
                          struct rt_i2c_msg         msgs[],
                          rt_uint32_t               num)
    rt_size_t ret;
    if (bus->ops->master_xfer)
#ifdef RT_I2C_DEBUG
        for (ret = 0; ret < num; ret++)
            i2c_dbg("msgs[%d] %c, addr=0x%02x, len=%d\n", ret,
                    (msgs[ret].flags & RT_I2C_RD) ? 'R' : 'W',
                    msgs[ret].addr, msgs[ret].len);
#endif
        rt_mutex_take(&bus->lock, RT_WAITING_FOREVER);
        ret = bus->ops->master_xfer(bus, msgs, num);
        rt_mutex_release(&bus->lock);
        return ret;
    else
        i2c_dbg("I2C bus operation not supported\n");
        return 0;
bus这个变量又通过好几层的参数传过来,有没有什么编辑器可以方便查看到他的付值的,或有什么好方法?
