[MCU] 关于LM4F232例程
817|0
 楼主| 两只袜子 发表于 2020-12-3 09:37 | 显示全部楼层 |阅读模式
lm, pi, IO, gp, GPIO
以下是网上看到的例程:
没能理解,求解。
int
main(void)
    volatile unsigned long ulLoop;
    // Enable the GPIO port that is used for the on-board LED.
    SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOG;
    // Do a dummy read to insert a few cycles after enabling the peripheral.
    ulLoop = SYSCTL_RCGC2_R;
    // Enable the GPIO pin for the LED (PG2).  Set the direction as output, and
    // enable the GPIO pin for digital function.
    GPIO_PORTG_DIR_R = 0x04;
    GPIO_PORTG_DEN_R = 0x04;
    // Loop forever.
    while(1)
        // Turn on the LED.
        GPIO_PORTG_DATA_R |= 0x04;
        // Delay for a bit.
       for(ulLoop = 0; ulLoop < 20; ulLoop++)
        // Turn off the LED.
        GPIO_PORTG_DATA_R &= ~(0x04);
        // Delay for a bit.
