[RISC-V MCU 应用开发] 【RISC-V MCU CH32V103测评】+显示温湿度
838|1
 楼主| masterqqq 发表于 2020-12-11 11:30 | 显示全部楼层 |阅读模式
实时测量环境温湿度OLED+DHT11
  1. #include "debug.h"
  2. #include "OLED_I2C.h"
  3. #include "dht11.h"
  4. /* I2C Mode Definition */
  5. #define HOST_MODE   0
  6. #define SLAVE_MODE   1
  7. /* I2C Communication Mode Selection */
  8. #define I2C_MODE   HOST_MODE
  9. //#define I2C_MODE   SLAVE_MODE
  10. /* Global define */
  11. #define Size   7
  12. #define RXAdderss   0x02
  13. #define TxAdderss   0x02
  14. /* Global Variable */
  15. u8 TxData[Size] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06 };
  16. u8 RxData[Size];
  17. /*******************************************************************************
  18. * Function Name  : IIC_Init
  19. * Description    : Initializes the IIC peripheral.
  20. * Input          : None
  21. * Return         : None
  22. *******************************************************************************/
  23. void IIC_Init( u32 bound, u16 address )
  24. {
  25.         GPIO_InitTypeDef GPIO_InitStructure;
  26.         I2C_InitTypeDef I2C_InitTSturcture;
  27.         RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE );
  28.         GPIO_PinRemapConfig(GPIO_Remap_I2C1, ENABLE);
  29.         RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
  30.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  31.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  32.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  33.         GPIO_Init( GPIOB, &GPIO_InitStructure );
  34.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  35.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  36.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  37.         GPIO_Init( GPIOB, &GPIO_InitStructure );
  38.         I2C_InitTSturcture.I2C_ClockSpeed = bound;
  39.         I2C_InitTSturcture.I2C_Mode = I2C_Mode_I2C;
  40.         I2C_InitTSturcture.I2C_DutyCycle = I2C_DutyCycle_16_9;
  41.         I2C_InitTSturcture.I2C_OwnAddress1 = address;
  42.         I2C_InitTSturcture.I2C_Ack = I2C_Ack_Enable;
  43.         I2C_InitTSturcture.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  44.   I2C_Init( I2C1, &I2C_InitTSturcture );
  45.         I2C_Cmd( I2C1, ENABLE );
  46. #if (I2C_MODE == HOST_MODE)
  47.         I2C_AcknowledgeConfig( I2C1, ENABLE );
  48. #endif
  49. }
  50. /*******************************************************************************
  51. * Function Name  : main
  52. * Description    : Main program.
  53. * Input          : None
  54. * Return         : None
  55. *******************************************************************************/
  56. int main(void)
  57. {
  58.     unsigned char i;
  59.         u8 a,b=0,k=0,j=0;
  60.         u8 ii=0;
  61.         extern const unsigned char BMP1[];
  62.         Delay_Init();
  63.         I2C_Configuration();
  64.         OLED_Init();
  65.         USART_Printf_Init(460800);
  66.         OLED_Fill(0xFF);
  67.         //Delay_Ms(500);
  68.         OLED_Fill(0x00);
  69.         //Delay_Ms(500);
  70.         while(1)
  71.                 {
  72.           char w[5],s[5];
  73.             u8 buffer[5];
  74.                         double hum;
  75.                         double temp;
  76.             if (dht11_read_data(buffer) == 0)
  77.                        {
  78.                           hum = buffer[0] + buffer[1] / 10.0;
  79.                           temp = buffer[2] + buffer[3] / 10.0;
  80.                        }
  81.          sprintf(w,"%d ",buffer[2]);
  82.          sprintf(s,"%d ",buffer[0]);
  83.         // printf("___{"temperature": %d, "humidness": %d}___\n", w, s);
  84.              for(i=0;i<2;i++)
  85.                 {
  86.                         OLED_Showint(1+i*16,0,i);
  87.                 }
  88.                 OLED_ShowStr(39,0,w,2);
  89.                     for(i=0;i<2;i++)
  90.                 {
  91.                         OLED_Showint(63+i*16,0,i+2);
  92.                 }
  93.                 OLED_ShowStr(103,0,s,2);
  94.                     //OLED_Drawch(0,0,'5',1);
  95.                     //ssd1306_refresh_gram();
  96.                 Delay_Ms(1000);
  97.              }
  98. }
海滨消消 发表于 2020-12-14 15:58 | 显示全部楼层
楼主很厉害啊
个人签名:32MCU单片机查询网 http://www.32mcu.com MCU选型,嵌入式设计辅助,选择最适合的MCU
35
