ucos报错,求教
1859|1
 楼主| denghaibo 发表于 2012-2-9 20:08 | 显示全部楼层 |阅读模式
ucos, ST, IDL, IO, se
(void)OSTaskCreateExt((void*)OS_TaskIdle,
                          (void *)0,                                 /* No arguments passed to OS_TaskIdle() */
                          (void *)&OSTaskIdleStk[OS_TASK_IDLE_STK_SIZE - 1], /* Set Top-Of-Stack                     */
                          OS_IDLE_PRIO,                              /* Lowest priority level                */
                          OS_TASK_IDLE_ID,
                          &OSTaskIdleStk[0],                         /* Set Bottom-Of-Stack                  */
                          OS_TASK_IDLE_STK_SIZE,
                          (void *)0,                                 /* No TCB extension                     */
                          OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);
UCOS这个函数报错<argument 1 to 'OSTaskCreateExt'> cast between function pointer and non-function object
出错停在最后一行,有高手知道吗?谢谢
李富贵 发表于 2012-2-9 22:49 | 显示全部楼层
把(void*)去了。
