372 374 圆柱型保险丝有什么区别?
3477|0
 楼主| wuljia 发表于 2009-4-14 16:57 | 显示全部楼层 |阅读模式
型号&nbsp;电子特性&nbsp;材料&nbsp;认证&nbsp;尺寸&nbsp;规格下载&nbsp;&nbsp;<br />370&nbsp;40mA-6.3A/250V/快断&nbsp;&nbsp;塑胶&nbsp;VDE/UR/CCC&nbsp;φ8.5x8mm&nbsp;<br />372&nbsp;40mA-6.3A/250V/慢断&nbsp;&nbsp;塑胶&nbsp;VDE/UR/CCC&nbsp;φ8.5x8mm&nbsp;&nbsp;<br />373&nbsp;50mA-10A/250V/快断&nbsp;&nbsp;塑胶&nbsp;UL/CSA&nbsp;φ8.5x8mm&nbsp;<br />374&nbsp;50mA-10A/250V/慢断&nbsp;&nbsp;塑胶&nbsp;UL/CSA&nbsp;φ8.5x8mm&nbsp;<br />382&nbsp;1A-10A/250V/慢断&nbsp;&nbsp;塑胶&nbsp;VDE/UR/CCC/PSE&nbsp;φ8.5x8mm&nbsp;<br />392&nbsp;800mA-6.3A/250V/慢断&nbsp;&nbsp;塑胶&nbsp;VDE/UR/CCC/PSE&nbsp;8.5x4x8mm&nbsp;<br />395&nbsp;50mA-6.3A/250V/快断&nbsp;&nbsp;塑胶&nbsp;UL/cUL/PSE&nbsp;8.5x4x8mm&nbsp;<br />&nbsp;<br />-----&nbsp;----&nbsp;----&nbsp;----&nbsp;---&nbsp;----&nbsp;<br /><br />8.5&nbsp;x&nbsp;8mm,&nbsp;250V,&nbsp;Time&nbsp;Lag,&nbsp;Sub-Miniature&nbsp;Fuses,&nbsp;Round&nbsp;Type,&nbsp;&nbsp;<br />UL/CSA/SEMKO/VDE/PSE/CCC&nbsp;Approved<br />&nbsp;<br /><br />&nbsp;8.5&nbsp;x&nbsp;8mm,&nbsp;250V,&nbsp;Time&nbsp;Lag,&nbsp;Sub-Miniature&nbsp;Fuses,&nbsp;Square&nbsp;Type,&nbsp;&nbsp;<br />UL/CSA/SEMKO/VDE/PSE/CCC&nbsp;Pending<br />&nbsp;<br /><br />仅仅是可选的电流范围&nbsp;和&nbsp;认证吗?
