GD32F450ZIT6 SPI0(PB3,PB4,PB5) 读取FLASH ID正确,但是读数据都是0xFF
1383|1
 楼主| salon_liu 发表于 2020-12-31 00:37 | 显示全部楼层 |阅读模式
我正在使用GD32F450ZIT6 SPI0(PB3,PB4,PB5) 读取SPI FLASH (WINBAND 25Q128JVSQ和GD 25Q127CSIG都试过)
读取得FLASH ID正确,但是读数据都是0xFF.
读写函数是“GD32F450IxH6_Demo板资料包/gd25qxx.c”中的
void spi_flash_buffer_write(uint8_t* pbuffer, uint32_t write_addr, uint16_t num_byte_to_write);
void spi_flash_buffer_read(uint8_t* pbuffer, uint32_t read_addr, uint16_t num_byte_to_read);
其他代码:
void spi_flash_init(void)
    spi_parameter_struct spi_init_struct;
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_GPIOG);
    rcu_periph_clock_enable(RCU_SPI0);
    /* SPI0_CLK(PB3), SPI0_MISO(PB4), SPI0_MOSI(PB5) GPIO pin configuration */
    gpio_af_set(GPIOB, GPIO_AF_5, GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5);
    /* SPI0_CS(PG13) GPIO pin configuration */
    gpio_mode_set(GPIOG, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_13);
    gpio_output_options_set(GPIOG, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_13);
    /* chip select invalid*/
    SPI_FLASH_CS_HIGH();
    /* SPI0 parameter config */
    spi_init_struct.trans_mode             = SPI_TRANSMODE_FULLDUPLEX;
    spi_init_struct.device_mode            = SPI_MASTER;
    spi_init_struct.frame_size             = SPI_FRAMESIZE_8BIT;
    spi_init_struct.clock_polarity_phase   = SPI_CK_PL_LOW_PH_1EDGE;
    spi_init_struct.nss                    = SPI_NSS_SOFT;
    spi_init_struct.prescale               = SPI_PSC_32;
    spi_init_struct.endian                 = SPI_ENDIAN_MSB;
    spi_init(SPI0, &spi_init_struct);
    /* set crc polynomial */
    spi_crc_polynomial_set(SPI0,7);
    /* enable SPI0 */
    spi_enable(SPI0);
int main(void)
  spi_flash_init();
  uint16_t i;
  uint32_t flash_id = 0;
  uint8_t tx_buffer[256];
  uint8_t rx_buffer[256];
  flash_id = spi_flash_read_id();
  printf("\r\nThe Flash_ID:0x%X\r\n",flash_id);
  printf("spi_flash_buffer_write!\r\n");
  for(i = 0; i < 256; i++){
    tx_buffer[i] = i;
        rx_buffer[i] = 0x55;
        printf("0x%02X ", tx_buffer[i]);
  printf("\r\n");
  /* erase the specified flash sector */
  spi_flash_sector_erase(0);
  delay_ms(100);
  /* write tx_buffer data to the flash */
  spi_flash_buffer_write(tx_buffer,0,256);
  delay_ms(100);
  /* read a block of data from the flash to rx_buffer */
  spi_flash_buffer_read(rx_buffer,0,256);
  printf("Check SPI flash the data!\r\n");
  /* printf rx_buffer value */
  for(i = 0; i < 256; i ++){
    printf("0x%02X ", rx_buffer[i]);
  printf("\r\n");
bjg0073128 发表于 2022-6-15 23:29 | 显示全部楼层
我也遇到这个问题
个人签名:工业控制:https://shop244451101.taobao.com/
