[STM8] STM8S105C6T6 UART2串口,能接收数据,不能发送数据
884|10
 楼主| elephant00 发表于 2021-1-4 17:16 | 显示全部楼层 |阅读模式
STM8S105C6T6 UART2串口,能接收数据,不能发送数据,哪位大神能帮忙看看。现在单片机自发自收没有问题,串口自发自收也没有问题,但是两个连接起来就单片机只能接收数据,发送数据,串口无接收
工具:USB转TTL
以下是程序代码:
void UART2_GPIO_init()
   GPIO_DeInit(GPIOD);
//GPIO_Init(GPIOD,GPIO_PIN_5,GPIO_MODE_IN_PU_NO_IT);//串口通讯TX
GPIO_Init(GPIOD,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST);
//GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);
GPIO_Init(GPIOD,GPIO_PIN_6, GPIO_MODE_IN_FL_NO_IT);//串口通讯RX
void UART2_ConfigurationInit(void)
UART2_GPIO_init();
  UART2_DeInit();
  UART2_Init((u32)9600,
             UART2_WORDLENGTH_8D,
             UART2_STOPBITS_1,
             UART2_PARITY_NO,
             UART2_SYNCMODE_CLOCK_DISABLE,
             UART2_MODE_TXRX_ENABLE);  //波特率 9600 8位数据  1个停止位  没有奇偶校验 关闭SCK 同意串口接受和发送
  UART2_ITConfig(UART2_IT_RXNE_OR,ENABLE);//开启读中断,接收数据寄存器非空或溢出错误中断
  //UART2_ITConfig(UART2_IT_TXE,ENABLE);//开启写中断
   UART2_Cmd(ENABLE);//启用串口
void UART2_Close()
  UART2_Cmd(DISABLE);
  UART2_ITConfig(UART2_IT_RXNE_OR,DISABLE);//关读中断,接收数据寄存器非空或溢出错误中断
  UART2_ITConfig(UART2_IT_TXE,DISABLE);//关写中断
void Send_Data(u8 Data)
  /*while((UART2_GetFlagStatus(UART2_FLAG_TXE)==RESET));
//待发送寄存器为空
      UART2_SendData8((unsigned char)Data);
     while((UART2_GetFlagStatus(UART2_FLAG_TC)==RESET));
//传输完成的标志
unsigned int j;
//待发送寄存器为空
  UART2_SendData8(Data);
//UART2_ClearFlag(UART2_FLAG_TC);
//j=50;
//while(j--);
//发送字符串Send_Str("STM8SUART \r\n")
void Send_Str(unsigned char *Data)
while(*Data!='\0')
   Send_Data(*Data);
   Data++;
INTERRUPT_HANDLER(UART2_TX_IRQHandler, 20)//发送数据中断
    /* In order to detect unexpected events during development,
       it is recommended to set a breakpoint on the following instruction.
   // 写操作自动清中断,因此可以不用显式清中断
//UART2_ClearITPendingBit(UART2_IT_TXE);
  * @brief UART2 RX interrupt routine.
  * @param  None
  * @retval None
INTERRUPT_HANDLER(UART2_RX_IRQHandler, 21)//接收数据中断
    UART2_ClearITPendingBit(UART2_IT_RXNE);
   Uart2RecData = UART2_ReceiveData8();
   Send(Uart2RecData);
   // 读操作自动清中断,因此可以不用显式清中断
// 注意这里的中断名是RXNE,不是RXNE_OR
  UART2_SendData8(Uart2RecData);
heimaojingzhang 发表于 2021-2-1 21:02 | 显示全部楼层
硬件上有没有复用啊
keaibukelian 发表于 2021-2-1 21:04 | 显示全部楼层
串口需要电阻匹配吗
labasi 发表于 2021-2-1 21:09 | 显示全部楼层
如果一直不让他发送数据  他可以接受数据吗
paotangsan 发表于 2021-2-1 21:11 | 显示全部楼层
用示波器看看总线上有波形吗
renzheshengui 发表于 2021-2-1 21:16 | 显示全部楼层
楼主如何确定没有发送出去数据呢
wakayi 发表于 2021-2-1 21:17 | 显示全部楼层
楼主硬件上是如何进行连接的呢
两只袜子 发表于 2021-2-8 15:44 | 显示全部楼层
应该是双机的RXD和TXD连接错了
两只袜子 发表于 2021-2-8 15:46 | 显示全部楼层
应该是双机的RXD和TXD连接错了
laocuo1142 发表于 2021-2-8 15:48 | 显示全部楼层
不要在 接收中断处理程序中,直接发送刚收到的数据,尽量减少中断处理时间;再说您的发送程序有 多处while  loop, 您可能在一直等待某个状态。
flycamelaaa 发表于 2021-2-8 15:49 | 显示全部楼层
把发送函数里最上面的两个语名位置掉换一下
