[其它应用] 提示修改了设置,但上电依然有3ma的高电流存在,会不会与rem有关
534|18
 楼主| happy_10 发表于 2021-1-4 21:01 | 显示全部楼层 |阅读模式
 楼主| happy_10 发表于 2021-1-4 21:05 | 显示全部楼层
还是其他原因,你们有没有这种芯片的测试数据?
bqyj 发表于 2021-1-4 21:11 | 显示全部楼层
你再详细一点说明一下
 楼主| happy_10 发表于 2021-1-4 21:14 | 显示全部楼层
单时钟工作76.8khz,3v工作电压,未使用rem,porte设置为输出低电平,其余端口作为输入输出,输入均有上拉,问题是上电开机瞬时电流3ma(持续200ms多),该电流与其他单片机相比太大了!
 楼主| happy_10 发表于 2021-1-4 21:17 | 显示全部楼层
我想了解一下有没有这方面的参考数据,还是我对rem或其他方面的设置有问题?
zhuhuis 发表于 2021-1-4 21:20 | 显示全部楼层
76.8KHZ?是不是32.768KHZ?
chenho 发表于 2021-1-4 21:23 | 显示全部楼层
把程序上传上来看看吧
 楼主| happy_10 发表于 2021-1-4 21:27 | 显示全部楼层
晶体频率是76.8khz
 楼主| happy_10 发表于 2021-1-4 21:33 | 显示全部楼层
RESET:
;    set special register and initialize
         NOP
         NOP
         LDI        SPR,00H                ;NO PULL UP
         LDI        PLCD,00H        ;LCD 1/4DUTY 1/3BIAS AND USE AS PORTC,D
         LDI        PACR,1100B        ;0:BUSY;1:SDA;2:RQS;3:SCK
         LDI        PBCR,0000B        ;0:0/ON/OFF;1:MM/INCH;2:-;3:-
         LDI        PCCR,1000B        ;3OWER CONTROL
         LDI        PDCR,1100B        ;0pt;1VP/CLR;2:WAIT;3:WORK
         LDI        PECR,0000B
         LDI        PORTE,0011B
        LDI        PORTC,1111B
         LDI        PORTB,1111B        B.3
         LDI        PORTA,0000B
         LDI        PORTD,1011B        A,PC,PD disable inter pull-up
         LDI        TEMP1,0FH        ;DELAY
         SBIM        TEMP1,01H        ;
         BNZ        $-1                ;
         LDI        PORTD,0011B        ;CLOSE
        LDI        TM0,02H
Clear_RAM:                       ;CLEAR RAM
         LDI        DPH,01H
         LDI        DPM,02H
         LDI        DPL,0FH
CR_LOOP:
         LDI        INX,00H
         SBIM        DPL,01H
         BNZ        CR_LOOP
         SBIM        DPM,01H
         SBI        DPM,07H
         BNZ        CR_LOOP
Clear_RAM1:                       ;CLEAR RAM
         LDI        DPH,00H
         LDI        DPM,07H
         LDI        DPL,0FH
CR_LOOP1:
         LDI        INX,00H
         SBIM        DPL,01H
         BNZ        CR_LOOP1
         SBIM        DPM,01H
         SBI        DPM,0010B
         BC        CR_LOOP1
         LDI        070H,00H
Clear_segments:
         LDI        TEMP1,00H
         STA        SEG1
         STA        SEG2
         STA        SEG3
         STA        SEG4
         STA        SEG5
         STA        SEG6
         STA        SEG7
         STA        SEG8
         STA        SEG9
         STA        SEG10
         STA        SEG11
         STA        SEG12
         STA        SEG13
         ldi        MODE,00H
         LDI        PORTB,0FH        ;
         LDA        PORTB,00H
         STA        STA_PB,00H
         BA1        $+2
         LDI        STAT0,01H        ;NO AUTO OFF
         LDA        STA_PB,00H
         BA0        $+3
         ORIM        MODE,08H
         ORIM        STAT3,01H        ;FLASH WHILE HALF SLEEPING
         LDI        STA_PD,1011B        ;ON
         STA        PORTD,00H
         LDA        PORTD,00H
         BA0        $+3
         ORIM        MODE,08H
         ORIM        STAT2,02H        ;OPT FOR DISPLAY
         ORIM        STAT2,08H        ;DIRECTION SELECT
         ORIM        STAT0,04H        ;zero
         LDI        STA_CS,05H
         LDI        TMP0,00H
         LDI        TMP1,00H
BUSY_LOW:
         LDI        PORTA,03H
         LDA        PORTA,00H
         BA0        BUSY_HIGH        ;BUSY HIGH
         ADIM        TMP0,01H
         BNC        BUSY_LOW
         ADIM        TMP1,01H
         BNC        BUSY_LOW
         ORIM        ERR,04H                ;NO BUSY
         JMP        LCD_ON
BUSY_HIGH:
         LDI        IRQ,00H
         LDI        PORTA,07H        ;RQS HIGH
         STA        ACC_BUF,00H        ;DELAY
         LDI        TEMP1,0FH        ;
         SBIM        TEMP1,01H        ;
         BNZ        $-1                ;
         LDI        PORTA,03H        ;RQS HIGH
         LDI        PARM,02H        ;DELAY        ABOUT 200MS
         CALL        Delay
LCD_ON:
         LDI        LCDON,4                ;LCD ON
;    main program
MAIN:
         JMP        MAIN
END
songqian17 发表于 2021-1-4 21:40 | 显示全部楼层
正确打开上拉电阻的方法:
1.设置I/O口方向寄存器为输入口.
2.将系统寄存器13的最高位置1
3.将I/O口数据寄存器写1
 楼主| happy_10 发表于 2021-1-4 21:41 | 显示全部楼层
我通过外接vdd或外接电阻至vdd方式,没使用内部上拉
chenho 发表于 2021-1-4 21:44 | 显示全部楼层
建议你先把设置为输入口的外接的VDD,或是电阻到VDD断开,在程序中打开内置的上拉电阻,并将主程序只写成
NOP
HALT
NOP
NOP
试一下.
另外,是用EVB仿真还是烧好芯片进行的测试?
 楼主| happy_10 发表于 2021-1-4 21:49 | 显示全部楼层
我测试了一下,200ms的时间大概就是初始化的时间,再试吧!
 楼主| happy_10 发表于 2021-1-4 21:55 | 显示全部楼层
通过烧好的芯片进行的测试,evb仿真时也试了,但没发现这么大的电流。
huwr 发表于 2021-1-4 21:59 | 显示全部楼层
其实规格要求使用32.768K晶振,你使用的76.8K晶振,属超规格要求使用,不建议这样使用
 楼主| happy_10 发表于 2021-1-4 22:02 | 显示全部楼层
哦,悲剧,重头再来了。。。
bqyj 发表于 2021-1-4 22:05 | 显示全部楼层
lz这说的是什么呀,什么上面有3ma的电流,引脚,电压,看不懂
wenfen 发表于 2021-1-4 22:08 | 显示全部楼层
也许有些芯片出厂有BUG,特别是使能上电串口下载时,由于ISP程序有BUG,某些管脚上电时异常。
 楼主| happy_10 发表于 2021-1-4 22:15 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈
