[技术问答] 关于N9H20K51GPIO中断问题
681|3
 楼主| probedog 发表于 2021-1-8 16:08 | 显示全部楼层 |阅读模式
//初始化后,gpio触发后一直未进中断,请各位谁玩过新唐N9H20K51 指点一下
void gpiocallback(void)
sysprintf("GPIO ------interrupt\n");
void GPIO_IRQHandler(void)
      INT32 mask;
      mask = 0x800;
      outpw(REG_AIC_SCCR, mask);   /* Clear interrupt */
     gpiocallback();
main()
                gpio_setportdir(GPIO_PORTE,BIT11,0);                 //RFGPIO 输入模式
                gpio_setintmode (GPIO_PORTE, BIT11, 1, 1);           //设置中断模式上升沿 和下降沿
                gpio_setsrcgrp(GPIO_PORTE,BIT11, 0);                 //设置中断源分组    GPEx pin被分组作为IRQ0的中断源之一
                gpio_setlatchtrigger(0);
                sysInstallISR(IRQ_LEVEL_2, IRQ_EXTINT1, (PVOID)GPIO_IRQHandler);
                sysEnableInterrupt(IRQ_EXTINT0);
                sysEnableInterrupt(IRQ_EXTINT1);
                sysEnableInterrupt(IRQ_EXTINT2);
                sysEnableInterrupt(IRQ_EXTINT3);
               sysSetLocalInterrupt(ENABLE_IRQ);
     while(1);
jcky001 发表于 2021-4-14 14:41 | 显示全部楼层
//IRQ_EXTINT1 = 3,
src = 1;  //IRQ1
gpio_setportdir(GPIO_PORTD, (1 << 6), 0);
gpio_setportpull(GPIO_PORTD, (1 << 6), 0);
gpio_setintmode(GPIO_PORTD, (1 << 6), 0, (1 << 6)); //rising enable
gpio_setsrcgrp(GPIO_ PORTD, (1 << 6), src);
gpio_setlatchtrigger(1 << src);
sysInstallISR(IRQ_LEVEL_1, src + 2, GPIOD_ISR);
sysSetInterruptType(src + 2, HIGH_LEVEL_SENSITIVE);
twjiang 发表于 2021-4-15 17:43 | 显示全部楼层
以下是 BSP 示例,看看你的代码少了什么?
void GPIOInterruptTest(void)
        int i;
        sysprintf("Connect GPB2 and GPB0 to test interrupt ......\n");
        gpio_setportval(GPIO_PORTB, BIT0, BIT0);                        /* Set GPB0 output high */
        gpio_setportdir(GPIO_PORTB, BIT0, BIT0);                        /* Set GPB0 output mode */
        sysInstallISR(IRQ_LEVEL_7, (INT_SOURCE_E)IRQ_EXTINT0, (PVOID)EXTINT0_IRQHandler);
        sysSetInterruptType((INT_SOURCE_E)IRQ_EXTINT0, HIGH_LEVEL_SENSITIVE);
        sysEnableInterrupt((INT_SOURCE_E)IRQ_EXTINT0);
        gpio_setportdir(GPIO_PORTB, BIT2, 0x0);                                /* Set GPB2 input mode */
        gpio_setportpull(GPIO_PORTB, BIT2, BIT2);                        /* Set GPB2 pull-high */
        gpio_setsrcgrp(GPIO_PORTB, BIT2, 0x0);                                /* set to IRQ_EXTINT0 */
        gpio_setintmode(GPIO_PORTB, BIT2, BIT2, 0);                /* Set GPB2 falling edge trigger */
        for(i = 0; i < 2; i++) {
                sysDelay(50);
                gpio_setportval(GPIO_PORTB, BIT0, 0);                                /* Set GPB0 output low */
                sysDelay(50);
jerow 发表于 2021-4-17 20:08 | 显示全部楼层
触发进不去,应该是初始化的问题,还有这个中断函数需要像STM32那样,写到启动函数中的吗?
