[STM32F1] stm32f1103串口问题求助
601|17
 楼主| chenjunt 发表于 2021-2-3 22:07 | 显示全部楼层 |阅读模式
STM32F103ZET6的串口1发送数据总是在上电后第一次发送数据前几位乱码,之后正常,再等一会后再发数据有乱码在发送就正常
happy_10 发表于 2021-2-3 22:10 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| chenjunt 发表于 2021-2-3 22:13 | 显示全部楼层
void USART1_Config(unsigned int bound)
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        /* ÅäÖô®¿Ú1 £¨USART1£© ʱÖÓ*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
        /*´®¿ÚGPIO¶Ë¿ÚÅäÖÃ*/
  /* ÅäÖô®¿Ú1 £¨USART1 Tx (PA.09)£©*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        /* ÅäÖô®¿Ú1 USART1 Rx (PA.10)*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        /* ´®¿Ú1ģʽ£¨USART1 mode£©ÅäÖà */
        USART_InitStructure.USART_BaudRate = bound;//Ò»°ãÉèÖÃΪ9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART1, &USART_InitStructure);
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//¿ªÆôÖжÏ
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        /* ʹÄÜ´®¿Ú1ÖÐ¶Ï */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        /*IRQͨµÀʹÄÜ*/
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        /*¸ù¾ÝNVIC_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèNVIC¼Ä´æÆ÷USART1*/
        NVIC_Init(&NVIC_InitStructure);
        USART_Cmd(USART1, ENABLE); //ʹÄÜ´®¿Ú
int fputc(int ch, FILE *f)
        // ½«PrintfÄÚÈÝ·¢Íù´®¿Ú
        USART_SendData(USART1, (unsigned char) ch);
        while( USART_GetFlagStatus(USART1,USART_FLAG_TC)!= SET);
        return (ch);
wenfen 发表于 2021-2-3 22:15 | 显示全部楼层
                    USART1->SR;
                    while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);
                    return(ch);
试试看这个代码
 楼主| chenjunt 发表于 2021-2-3 22:17 | 显示全部楼层
还是不行啊 , 上电第一次还是前几个乱码,之后就正常了。
spark周 发表于 2021-2-3 22:21 | 显示全部楼层
有图吗
 楼主| chenjunt 发表于 2021-2-3 22:28 | 显示全部楼层
wangzsa 发表于 2021-2-3 22:33 | 显示全部楼层
软件方面,主要两边波特率配置一致就好,
dingy 发表于 2021-2-3 22:35 | 显示全部楼层
建议重点检查下硬件线路。
 楼主| chenjunt 发表于 2021-2-3 22:37 | 显示全部楼层
恩恩 应该找到问题了,是串口芯片的问题,ttl直接出来接收就不乱码,过串口芯片就会出现这个问题。
renyaq 发表于 2021-2-3 22:40 | 显示全部楼层
对文件没有操作过 帮不了楼主了
supernan 发表于 2021-2-3 22:42 | 显示全部楼层
把速度降下来试试看
 楼主| chenjunt 发表于 2021-2-3 22:44 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
keaibukelian 发表于 2021-3-1 23:13 | 显示全部楼层
有没有干扰产生了
labasi 发表于 2021-3-1 23:15 | 显示全部楼层
看来是电平的问题啊
paotangsan 发表于 2021-3-1 23:18 | 显示全部楼层
乱码有规律性吗
renzheshengui 发表于 2021-3-1 23:20 | 显示全部楼层
通讯速度不快啊
wakayi 发表于 2021-3-1 23:24 | 显示全部楼层
应该不是通讯速度的问题
