[STM32] STM32F030C8T6的定时器怎么不准【解决】
919|4
 楼主| ddllxxrr 发表于 2021-2-4 09:27 | 显示全部楼层 |阅读模式
我用STM32F030C8T6我用定时器延时,SYSTICK想给别的用比如OS,反正留用。
我在初使化的时候我已经把APB时钟2分频别的地方要用。
  1. if (HSEStatus == (uint32_t)0x01)
  2.   {
  3.     /* Enable Prefetch Buffer and set Flash Latency */
  4.     FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
  5.     /* HCLK = SYSCLK */
  6.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  7.
  8.     /* PCLK = HCLK */
  9.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV2;  //    //24MHZ
  10.     /* PLL configuration = HSE * 6 = 48 MHz */
  11.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  12.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
  13.
  14.     /* Enable PLL */
  15.     RCC->CR |= RCC_CR_PLLON;
我的延时程序如下:
  1. void TIM_Config(void)
  3.   TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  4.     /* TIM3 clock enable */
  5.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  6.   /* Compute the prescaler value */
  7.   PrescalerValue = (uint16_t) (SystemCoreClock  / 1000000) - 1;
  8.   /* Time base configuration */
  9.   TIM_TimeBaseStructure.TIM_Period = 1;  //1 u second
  10.   TIM_TimeBaseStructure.TIM_Prescaler = 23;//PrescalerValue;
  11.   TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  12.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;
  13.   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  14.   TIM_Cmd(TIM3, DISABLE);
  15. }
  16. void TimeDelay1us(uint16_t Times)
  17. {
  18.   TIM3->CR1 |= TIM_CR1_CEN;  //启动定时器
  19.   while(Times--)
  20.   {
  21.      while((TIM3->SR & TIM_FLAG_Update) == RESET);
  22.          TIM3->SR &= ~TIM_FLAG_Update;
  23.   }
  24.    TIM3->CR1 &= ~TIM_CR1_CEN;  //关闭定时器
  25. }
  26. void Delay(uint16_t Times1)
  27. {
  28.         uint16_t dd,count;
  29.         for(count=0;count<Times1;count++)
  30.         {
  31.              for(dd=1;dd<1000;dd++)
  32.              TimeDelay1us(1);
  33.         }
  34.
  35. }
  36. void delay_us(uint16_t Times2)
  37. {
  38.           uint16_t count;
  39.         for(count=0;count<Times2;count++)
  40.         {
  41.               TimeDelay1us(1);
  42.         }
  43. }
  44. void delay_ms(uint16_t Times3)
  45. {
  46.           uint16_t count;
  47.           for(count=0;count<Times3;count++)
  48.           Delay(1);
  49. }
我运行了一下,怎么将4秒,而我定时是1秒。而且好像我改变参数时间并不变求解。
 楼主| ddllxxrr 发表于 2021-2-6 08:11 | 显示全部楼层
计算错误加程序上的事。结贴
cainiao518 发表于 2021-2-6 09:47 | 显示全部楼层
计算错误加程序上的事。结贴
正确的程序是怎么样的呢
 楼主| ddllxxrr 发表于 2021-2-6 14:05 | 显示全部楼层
这就是正确程序,定时是2US,由于没有用中断,延时有伤停补时,最后是350正好是1秒,亲测!!!
  9.   TIM_TimeBaseStructure.TIM_Period = 1;  //2 u second
  15. }
  16. void TimeDelay2us(uint16_t Times)
  17. {
  19.   while(Times--)
  20.   {
  23.   }
  25. }
  27. {
  30.         {
  31.              for(dd=0;dd<350;dd++)  //必须延这么多才到1秒
  32.              TimeDelay2us(1);
  33.         }
  34.
  35. }
  36. void delay_us(uint16_t Times2)   //2倍
  37. {
  38.           uint16_t count;
  40.         {
  41.               TimeDelay2us(1);
  42.         }
  43. }
  45. {
  46.           uint16_t count;
  48.           Delay(1);
  49. }
2us能反应过来吗?  发表于 2021-2-8 20:13
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
