[AT32F421] AT32_IEC 60730_CLASSB软件库使用指南(增加AT32F421支持)
3262|6
 楼主| ArterySW 发表于 2021-2-5 10:59 | 显示全部楼层 |阅读模式
前言
这篇应用笔记描述了AT32系列的MCU如何执行IEC 60730中所要求的软件安全性相关的操作。
支持型号列表:
支持型号
AT32F403xx
AT32F413xx
AT32F415xx
AT32F403Axx
AT32F407xx
AT32F421xx
目录
概述 .......................................................................................................................... 5
程序结构说明 ........................................................................................................... 6
启动时检测流程 ........................................................................................................ 7
CPU 启动时检测 ........................................................................................................... 8
看门狗启动时检测 ......................................................................................................... 9
FLASH 启动时检测 ..................................................................................................... 10
RAM 启动时检测 ........................................................................................................ 13
时钟启动时检测 .......................................................................................................... 14
控制流启动时检测 ....................................................................................................... 15
运行时周期检测流程 ............................................................................................... 16
CPU 运行时检测 ......................................................................................................... 16
堆栈边界运行时溢出检测 ............................................................................................ 17
系统时钟运行时检测 ................................................................................................... 18
Flash CRC 运行时检测 ............................................................................................... 19
看门狗运行时检测 ....................................................................................................... 20
局部RAM 自检 ........................................................................................................... 20
软件demo 演示 ...................................................................................................... 21
版本历史 ................................................................................................................ 23
AN0041_AT32_IEC 60730_CLASSB_LIB_ZH_V1.0.1.pdf
1.05 MB, 下载次数: 183
IEC_60730_CLASSB_demo_V1.0.1.zip
30.83 MB, 下载次数: 572
小明的同学 发表于 2021-3-1 19:15 | 显示全部楼层
学习下这个芯片操作。
fcccc 发表于 2021-4-8 20:44 | 显示全部楼层
看起来非常像xT的X_CUBE_STL的操作.
fcccc 发表于 2021-4-8 20:51 | 显示全部楼层
也是没有外设的测试,比如ADC测试,比较器测试,GPIO测试,UART/或者其他通信接口测试给个案例就好了.
单片小菜 发表于 2021-4-8 21:43 | 显示全部楼层
持续关注中,一直在关注这个芯片,看看这个芯片怎么样。
真爱吴迪迪 发表于 2021-4-9 09:09 | 显示全部楼层
这是一篇经典的**,不错的,可以进行深入的学习一下的芯片,感谢楼主的分享。
LemonRK 发表于 2021-9-9 13:47 | 显示全部楼层
不错的
